200 Lbs
Old May 18, 2005 | 12:14 PM
99NVRam2500's Avatar
200 Lbs
Is there any way to make this thing ride like it has 200 lbs in the bed? It rides really comfortable like that, but like a darn 3/4 ton TRUCK with out it. Man, I must be spoiled.
Old May 18, 2005 | 12:16 PM
Buckshotmckee's Avatar
Hoss can answer this. Concrete Bedliner?
Old May 18, 2005 | 02:16 PM
HappyGA's Avatar
Steering shaft extension and driver seat moved to bed maybe???
Old May 18, 2005 | 02:19 PM
67HotRod's Avatar
Put 200lbs in the bed. I have an ample supply of firewood at all times.
Old May 18, 2005 | 03:23 PM
P.J's Avatar
P.J
How about looking at Tire pressure (when not towing)??
Old May 18, 2005 | 05:04 PM
upersleder's Avatar
racecar trick, bolt 200# to the frame...........
Old May 19, 2005 | 10:48 PM
high country's Avatar
wow you must have a much lighter truck then me, mine starts to ride good around 1000 lbs in the bed
Old May 19, 2005 | 10:55 PM
Bluedeviltorque's Avatar
ONLY 200lbs in the bed???? If someone put 200lbs in the bed of my truck with out telling me I wouldn't know unless I heard the weight slide around the bed under my toneau cover. It takes about 600lbs in my current truck to notice any change in ride. But what ever you put back there make sure you secure it so it doesn't end up going through your back window.
Mike
Old May 22, 2005 | 08:33 PM
Tom Bolitho's Avatar
Two hundred pounds? In the bed or at the bumper? Solve two problems at once. Get an auxillary tank in the bed and fill it with fuel. 25 gallons and the weight of the tank will be 200 pounds.
Oct 22, 2003 11:25 AM
BIG&BAD
Oct 12, 2003 02:54 PM
belfert
Oct 12, 2003 11:25 AM
JImbo1
Aug 27, 2003 08:13 AM
badassvan
Nov 26, 2002 01:04 PM
