1999 Dodge Ram transmission will not upshift.
Old Oct 29, 2008 | 02:22 AM
Willieb.42's Avatar
I have a 1999 Dodge Ram club cab 2500 5.9L cummins and had the transmission rebuilt. Transmission shop stated that the transmission was bad and after replacing the transmission I still have the same problem, Transmission was not the problem. Transmission still will not upshift. There is a code set in the pcm P1693. Any suggestions on this problem?
Old Oct 29, 2008 | 08:38 AM
j-fox's Avatar
1693 simply says there are other codes.
When they replaced the trans, did they reuse the pressure transducer and solenoid? Or did they reuse them?
Also look at the speed sensor.
Old Oct 29, 2008 | 09:32 AM
raychem's Avatar
Also adjust your TV cable!!
Richard
Old Oct 29, 2008 | 10:03 AM
Willieb.42's Avatar
I checked the PCM with my scanner and there are no codes displayed. But if I check the freeze frame data the code P1693 is displayed. The transmission shop did replace the pressure transducer and solenoid and wireing harness for them also.
Old Oct 31, 2008 | 05:39 AM
daddy mopar's Avatar
Fuel pump
I was having the same trouble in my truck. Shop wanted to rebuild the transmission but couldnt give me a good reason why! I said no and a month later the VP44 fuel pump went out. After some research, I found that if the engine starves for fuel the ECM will compensate for everything including acceleration. My upshift was sometimes hard and drawn out, shifted at random, high RPM's and never seemed to have a set shift point. It might be worth it to check your lift pump and VP44. Just an idea.
Old Oct 31, 2008 | 06:35 AM
dozer12216's Avatar
No upshift equals no governor pressure, based on your description of issue.
Now for the rest of story. Gov pressure Solenoid and transducer were changed in 2000. 1999 and 2000 are not interchangable, nor are the computers.
Futher, need to check gov pressure. the port is on right rear upper area of tranny case. It is pointed straight back. As vehicle speed increases the gov pres should rise at a 2 to one ratio. IE, 20 MPH equals approx 40 PSI(diesel).
Should be able to tell about lack of power. From your description I assume it pulls out normally, but does not upshift to second by 20 MPH even if let off go pedal.
Old Oct 31, 2008 | 10:35 AM
Willieb.42's Avatar
Thanks for the information. You are correct the truck will not shift to 2nd gear. It pulls out normally, but does not up shift to second by 20 MPH even if let off go pedal. Is there a special gauge I need to measure the governor pressure?
Old Oct 31, 2008 | 11:02 AM
johnh's Avatar
i would have the trans shop fix it. after all, you paid for it!
Old Oct 31, 2008 | 12:24 PM
musthave's Avatar
I have the same problem except it will shift if I slack of the pedal. But after the first shift (1st to 2nd) transmission shift ok in 1st to 2nd. I had the transmission overhauled but didn't solve the problem took it back to the shop twice with the same result. I'am just living with it.
Old Dec 20, 2008 | 03:48 PM
MATTIEBOB's Avatar
did this problem ever get figured out
Old Dec 20, 2008 | 07:13 PM
Dinner's Avatar
My truck did the same as Musthave said. Wouldn't shift from 1st to 2nd unless throttle was let off, after that the tranny shifted fine. Hooked a scanner up through OBD-II and found that there wasn't any pressure at the Governor Solenoid. I ended up replacing my entire Valve Body since I wanted to upgrade anyways (Came with new Governor and Transducer Solenoids).
Old Dec 22, 2008 | 09:59 AM
dozer12216's Avatar
Willieb.42 The gov solenoid is probablly stuck wide open. I suspect a new sol will fix you right up.
Old Dec 22, 2008 | 03:46 PM
RowJ's Avatar
Common problem. I've had exact same problem twice in 170,000 miles. Simple do-it-yourself fix. I would change tranny shops.
Change out Governor Soleniod and Trasnducer... as suggested.
RJ
Old Dec 22, 2008 | 07:12 PM
Stamey's Avatar
Did you try replacing the speed sensor in the transmission? When my 99 decided it would not shift 1st to 2nd until I let off, then got worse, to the point it would not shift out of first at all, I called my tranny guy and he told me to put a speed sensor in it. 20 bucks at Advance and it was fixed. I did try swapping the one out of my 96 first, to make sure though.
Chris
Old Dec 24, 2008 | 02:17 PM
american racer's Avatar
im having the same problems i know what i will be doing for christmas...thanks guys ill let you all know the results
