1 ton front wheel bearing
Old Apr 6, 2006 | 07:55 PM
Copenhagenjunkie's Avatar
Got the rear shocks done and moved on to the front brakes. I noticed I have some up and down play with the hub- not sloppy loose but questionable when the caliber is off. No grease leaking. Is this normal? The reason I ask is because I don't remember it having play when I did my brakes last- which was about 3 yrs ago. Did I just forget there was some play before?
I am leaving on a trip in a week and don't need any problems.
Thanks for info.
Old Apr 6, 2006 | 08:13 PM
Angry
I am so mad I am shaking. Drivers side bearing is shot because the passenager side is tight. I barely remember doing the pass side but what I do remember that is was one tough bugger. I will bet our dealership won't have one in stock either. It is a dealer only part?
Old Apr 6, 2006 | 08:49 PM
nitrousn's Avatar
If its not growling make sure the axle nut is torqued properly. If it is loose the bearings will seperate slightly and become loose.
Old Apr 6, 2006 | 09:00 PM
singleturnout's Avatar
i had to replace mine dealer wantd 360.00 i ended up going to a salvage yard and got one for 100.00 or you could try quad4x4.com there resonable
Old Apr 6, 2006 | 09:20 PM
Well I got it off, it wasn't too tuff but I did work up a sweat. It's shot. I will try quad. I really need one tomorrow, I have a weekend of corral cleaning to do. I guess I could persuade the boss to let me take a college vehicle home .
Old Apr 7, 2006 | 09:16 AM
Thankfully I don't has ABS so I can get one from the dealer for $345.60 and they have some in stock. .
silverbullet02
Oct 5, 2009 12:16 PM
Wilbur01
Aug 3, 2009 11:16 PM
Hawkeye
Apr 29, 2008 10:24 AM
Free89W350
Mar 24, 2008 08:04 PM
