02' fuel pump question ?
Old Jun 4, 2007 | 04:35 PM
O.fO.shO's Avatar
I went to install a vulcan draw straw in the tank and to my surprise I have an in-tank pump . I think I have a pump mounted on the block . As you know its kind of in a tight spot , and right before the fuel filter .....unless I've got it all wrong and thats not a pump ?
So can it be the previous owner had an in take pump installed in conjunction with the stock pump ? I'm only seeing 7psi at idel currently , which is odd if so .
In any case I need the Vulcan draw straw2 , and probably a new pump . I have a seperate fuel system with a FASS that I use most of the time drawing from a seperate tank . So I need the cheapest possable pump that will work for my stock fuel system , any suggestions ? I am running it in all 1/2" fuel lines .
retirednak
Mar 30, 2010 11:00 PM
3500_CTD
14
Feb 5, 2008 08:33 AM
ScreaminEagle
Oct 31, 2007 03:31 PM
Stevie G
13
Aug 4, 2006 10:27 PM
Commatoze
19
Aug 8, 2004 09:57 PM
