Losing Prime??
Old Jun 4, 2007 | 10:43 AM
jbevly's Avatar
Losing Prime??
I had a fuel pressure gauge installed this weekend. Brought the truck home and it sat for about 15 hours. It did not want to start, had to crank it for a very long time. Let it sit for a couple of hours or less and it starts right up. Also when I get out after driving it, I can smell diesel. No leak found on the ground as of yet. Any ideas? Something the did not tighten when they put the gauge on?
John
Old Jun 4, 2007 | 10:56 AM
pick's Avatar
sounds like something's not tight. Check the schreider Valve on the pump.
Old Jun 4, 2007 | 01:07 PM
RowJ's Avatar
If you can smell it....you ought to be able to find the fuel leak.
Not starting cold is very different than not starting hot. Try bumping the starter (without turning the starter over). this should activate the Fuel pump to repressurize the system. let pump run for 5-7 sec (you can hear it and see it on you FP gauge) and than try starting it.
I have the same problem on a cold engine, when my tank gets below 1/2. Bumping the starter works every time.
RJ
Old Jun 4, 2007 | 01:49 PM
jbevly's Avatar
Does the "starter bump" trick work with the in tank pump?
Old Jun 4, 2007 | 02:05 PM
RowJ's Avatar
Should...can't think why it would not...but you'll have to try it and see?
If it's working you'll see pressure coming up on your gauge (in case you can't hear the in-tank pump). Pump will run for about 20 sec before it shuts off...if truck is not started.
RJ
Old Jun 4, 2007 | 02:16 PM
cmckinney's Avatar
Go back and check all of your connections. It sounds like a very slow leak is allowing air into your fuel system. Been there done that!
Who installed your pressure gauge? Is it mechanical with fuel line in the cab or is it an electronic version?
-CM
Old Jun 4, 2007 | 02:28 PM
jbevly's Avatar
It is electric. I called the shop that did the install and they are going to check it out. I just hope they find it, not a good feeling in the morning that my truck won't start and I need to get to work!
Old Jun 4, 2007 | 02:30 PM
cmckinney's Avatar
Previous problems with electronic FP gauges included diaphrams that were bad. Just a thought so check that part out.
Good luck. I know it's a bad feeling to see your truck not start right up but you'll get it fixed.
-CM
Old Jun 4, 2007 | 02:38 PM
jbevly's Avatar
Diaphrams in the gauge sending unit? Well as long as the shop can fix it, I will be happy. I'm just ready to go back to it being perfect!
Old Jun 4, 2007 | 04:56 PM
cmckinney's Avatar
Yes I think that was an issue. Maybe someone on the board with more knowledge can comment. Bottom line is that air is infiltrating into your fuel system causing it to hard start. I had a similar issue when I put a new set of injectors in the truck. One day it just started to hard start I finally uninstalled the injectors and foudn that one of them was slightly unseated. Hence the air infiltration into the system after 6-8 hours.
Good luck.
Crimedog
16
Oct 28, 2006 01:23 PM
smokeyram
Apr 5, 2006 07:17 PM
cmckinney
43
Mar 16, 2006 04:13 PM
GearHd6
Nov 4, 2005 06:51 PM
cummins2
13
Jan 21, 2005 04:56 PM
