02 engine w/auto trans dogging at 1500 rpm
Old Oct 1, 2008 | 08:02 PM
ace roper's Avatar
02 engine w/auto trans ******* at 1500 rpm
I just bought a 02 24 valve with an auto trans. problem is that when I am going at 55 mph / 1500 rpm, I could feel the trans shift into a neutral state and there is no power whatsoever until I let the rpm drop to idle then it takes off again or it will slowly downshift. I checked the codes on the odometer and it read p0500 and p1693. I need help!!
Old Oct 1, 2008 | 08:40 PM
dozer12216's Avatar
P0500 = no vehicle speed sensor signal. Can cause all of above even if speedo does work.
Be sure an check lift pump pressue. Check wiring harness on left frame rail to cneter of axle. Had plenty issues with wiring being fubarred.
Old Oct 1, 2008 | 10:09 PM
ace roper's Avatar
thanks,
I replaced the speed sensor and when I was disconnecting the sensor wire, I found another wire hanging next to the sensor connection... I tried to find out where this wire should have been connected to, but did not find anything. I thought that this might be a test point or something.
waldersha
Mar 13, 2009 09:05 PM
skeeter
Jan 18, 2006 03:17 PM
fishin fever
Feb 22, 2004 08:32 PM
