01 VP44 Issues
Old Jan 10, 2011 | 09:21 AM
BryanC's Avatar
01 VP44 Issues
I am new to this forum and have read a lot of the threads here about the VP44, the other day I drove my 01 Dodge Ram 3500 24valve dually to work with no issues, came out from work and it just cranked over and over with no start, the battery cables are clean and I am getting fuel through the LP to the VP44. Yesterday I hooked up my scanner and recieved the "Grime Reaper" of codes P1688 , and by the way it was the only code shown. My question is, should I go and just buy a new IP or should there be steps that I should take to rule out a possible error with the code? (I know I'm reaching) I notice from reading some of the threads that sometimes it can be something else that seems to trigger the code, could it be the electronics in the pump and I can simply replace that or am I just prolonging the inevitable.
Any and all suggestions are appreciated
Thanks
Old Jan 10, 2011 | 10:22 AM
Russ Roth's Avatar
This will be helpful. Good luck.
http://www.bluechipdiesel.com/vp44diagnostichelp.html
Old Jan 10, 2011 | 11:06 AM
Backwoods Bumpers's Avatar
Vendor - Former Vendor
There's absolutely nothing wrong with running diagnostics, but most likely it's time for a new IP. If you've never done one before, there is an excellent write up on here somewhere. I'll see if I can find it......
mopar440cu
Nov 28, 2012 10:33 PM
DieselRebel24
Dec 4, 2010 03:22 PM
Erska
17
Mar 6, 2009 09:52 PM
Smokin'02
Feb 25, 2007 08:39 PM
Timmay2
25
Feb 12, 2006 01:00 AM
