Yet MORE brake B.S.
Old Jul 31, 2020 | 10:16 PM
red_fir_smoke's Avatar
I dunno? there always a tube on them going into a reservoir of brake fluid, but it doesn't seem like an extraordinary amount!
I wondered if maybe the calipers were "sticky" and not reacting well but I would have thought that after a few cycles a "sticky" caliper would free up?
Old Aug 1, 2020 | 06:33 AM
BHD's Avatar
BHD
I have never had any luck with a caliper becoming freed up on its own, but they usually stick in the extended position, not the retracted position.
The brake bleeder with a tube into a reservoir is a nice and clean way to bleed the system, but it can sometimes hide a low pressure issue.
Old Aug 1, 2020 | 09:59 AM
So what would cause a low pressure issue?
(this is the 3rd master, and this issue has persisted across all of them)
If I put a gauge between the master and the front brake line what pressures am I looking for?
Old Aug 1, 2020 | 10:59 AM
Fordzilla's Avatar
Collapsed brake hose, kinked steel brake line, an abundance of crud buildup inside a caliper from years of replacing pads without rebuilding the caliper......Ben
Old Aug 2, 2020 | 11:07 AM
BHD's Avatar
BHD
What he said.
I just bought a '94 2500 that had little to no brakes due to seized up calipers. Being as cheap as I am, I bought the rebuild kits vs reman units.
Brake fluid is hygroscopic and I try to change mine about every 2 years in all my junk. It has saved me from replacing major braking components.
As far as using a gauge to determine how much pressure you should have is above my pay grade.
Old Aug 2, 2020 | 09:21 PM
Originally Posted by BHD
What he said.
You been signing legislation in NJ, lately ?
Old Aug 3, 2020 | 04:57 PM
BHD's Avatar
BHD
Tman, IF I was signing legislation there would be lot of people with a one way ticket to the slammer or a chain gang.
Lucky for the world, I am just a dumb farm kid with an addiction to old Dodge iron.
Old Aug 4, 2020 | 06:46 AM
maybe368's Avatar
Keep the politics out of the the technical forums please. Take it over to the political forum. I can see how it's no fun when everyone agrees with each other, you need a foil ...Mark
bigragu
Oct 14, 2015 10:29 AM
bannerd
Sep 6, 2012 10:03 AM
ajg617
14
May 8, 2007 10:14 AM
timb
Jun 3, 2005 09:11 PM
Dieseldude4x4
15
Feb 18, 2005 06:07 PM
