Wrench Size To Replace Transmission Yoke
Can anyone tell me the size wrench needed to remove and replace the drive-shaft yoke on a 2WD Getrag??
Is there anything else I should know before undertaking this??
I will need to drain the oil, yes??
I just remove the nut, slide off the old, slide on the new, and replace the nut, right??
I won't have to be concerned about getting something out of adjustment, right??
Many thanks.
Many thanks.
I answered my own question.
Wrench size is 1-3/16", actually probably communist/metric, as the SAE was a shade loose.
I got the drive-shaft out of the way; then, I strained my guts out and loosened the nut in the center of the yoke.
The old slid off and the new slid in; no oil poured out all over me.
I put a drop of red thread-locker on two sides of the nut and tightened the living daylights out of the nut.
Mission accomplished.
trik396
05-31-2005 05:09 PM
1tuffdiesel
06-27-2004 06:29 PM
