Is it worth uprading the H1c compressor housings?
Old Mar 11, 2009 | 02:20 PM
jesussaves's Avatar
I noticed on Gillet diesel website their are several choices for the 93. I have a 16cm ex housing already and i use my truck mainly for towing. What would be the best choice and what are the effect of a smaller vs larger compressor housing. What kind of performance can i expect from theses? http://www.gillettdiesel.com/turboch...pgrades-2.aspx
Old Mar 11, 2009 | 02:23 PM
The_Head's Avatar
You're talking about the exhaust housings.
Old Mar 11, 2009 | 02:27 PM
jesussaves's Avatar
Sorrry Im looking at the differences with the compressor housing and wheel combo to flow more air
Old Mar 11, 2009 | 03:04 PM
Mattster's Avatar
60mm will definitely flow alot more air. And they sound nice with the MWE slot.
Old Mar 11, 2009 | 03:17 PM
If you are keeping the stock injectors then a compressor upgrade is worth the money. If you are putting in big ol' injectors and want to keep towing, save the money towards a bigger better turbo.
Old Mar 11, 2009 | 04:30 PM
MBolivar's Avatar
What he said. I'm only running 190's with aggressive pump settings and timed @ 15*. My 60mm struggles to keep it at 1300 on the pyro.
Old Mar 11, 2009 | 04:34 PM
archer39's Avatar
yep, you got to use your head if you only got the 60mm upgrade and large injectors.
Old Mar 11, 2009 | 05:22 PM
14racing's Avatar
I've been pretty happy with my 60mm upgade so far but im only running stock injectors. The sound over the stock h1c was well worth the money to me. Egt's seem a bit cooler.
Old Mar 11, 2009 | 05:27 PM
archer39's Avatar
Yes the sound is well worth it
Old Mar 11, 2009 | 06:18 PM
sshort's Avatar
I run the 60mm upgrade with a 18.5 exhaust housing & stock non i/c injectors & still could use more air I have not turned the pump all the way up because of egt,s go ballistic I made a new intank with two tapped holes. almost ready for water/meth cant wait
The_Head's Avatar
https://www.dieseltruckresource.com/...d.php?t=225526
This might help you some too.
Old Mar 11, 2009 | 06:37 PM
sshort's Avatar
Im lost what help was that
Old Mar 11, 2009 | 07:23 PM
The_Head's Avatar
The man tells you how much power it is good for.
Old Mar 11, 2009 | 07:44 PM
jesussaves's Avatar
thats the info i was looking for, i will be getting 140 hp injectors from coal train down the road. So if you go with larger injectors does that mean you have to get a larger turbo? what would happen with the stock h1c? high egt's?
Old Mar 11, 2009 | 08:03 PM
Originally Posted by jesussaves
high egt's?
Exactly. If your truck is a play truck, you can "get by" with a hybrid and big injectors, but if you want to get the full power potential and have safe EGT's for towing you will need a bigger turbo like an HX-40 or S300 variant.
