wiring help (burning smell)
Hello, first off let me say this truck has never had the wiring harness butchered and is all stock as far as the wiring goes. I took the truck to the dump today to take a load of junk in. On the way home I started smelling a burning wire smell. I got home and popped the hood and couldn't see of feel anything that seemed hot. The smell seemed like it was stronger on the battery side. But it was hard to tell. Since I'm new to working on these, where do you think I should start looking? Is there any typical problems? Thanks in advance.
My HVAC switch did that to me this winter. I wondered why I smelled a burning wire smell and then my HVAC fan switch stopped working. When I replaced it it was all melted. Are you sure it's coming from under the hood?
No I'm not sure it's coming from under the hood. I smelled it first inside the cab. I looked at all the wiring on the drivers side and nothing looks bad. Is there a way to check the fusible links besides just looking at them? Everything seems to work. I'll have to go check the blower motor switch to make sure. I felt everything and nothing was hot. I'll check the fuse box and the hvac switch. I did turn the blower off on the way to the dump.
On the fire-wall, near the master-cylinder, is a big square "bulk-head" connector with a bolt through it's center.
The mating half of this is inside the cab, under the dash.
I am almost certain that there is a write-up in the "sticky" explaining how to clean up and re-work the bulk-head connector.
The terminals and wires are much too small for the job they do; and, old age and oxidation cause high resistance in the terminals, thus melting the surrounding plastic.
HorseHauler
17
Feb 23, 2010 02:46 PM
belfert
15
May 6, 2004 06:14 PM
aklabs
Apr 2, 2004 01:05 PM
2nGlenn
Mar 11, 2003 01:51 PM
