Wiring diagram needed - 1992 headlight switch
Old Dec 20, 2006 | 09:51 AM
4RnrRick's Avatar
I need a wiring diagram for the headlight switch for a 1992. A previous owner has cut out the original plug off from the main dash harness and spliced in a new plug with a couple different wire colors on it.
Not to mention it looks like they rewired the cab running lights to the dash dimmer switch, removed the ignition ring light timer, My headlights flicker everytime the tranny shifts and my tail lights don't work. I already swapped in a new headlight switch and that didn't fix the tail lights; So my plan is to redo the hack job but I need a wiring diagram of the headlight switch. Anybody got one?
Old Dec 20, 2006 | 10:21 AM
ofcmarc's Avatar
I believe that there is a 91.5 diagram in the "sticky" should be close enough for goverment work.
Old Dec 20, 2006 | 11:10 AM
4RnrRick's Avatar
Found them - thanks.
'91.5 wiring diagrams
http://dens-site.net/Dodge_CTD/1991.5-Wiring_Diagrams/
Old Dec 20, 2006 | 12:55 PM
4RnrRick's Avatar
On Sheet "AD22" which is Scan 25, it calls out
H4 20BK - { To Key-in Lamp (See SH 41)
Which I assume is the Ignition Ring Light and timer wiring.
Anyone got Electricals Sheets above "AD 35" ????
Old Apr 17, 2019 | 11:01 AM
benny b's Avatar
What does it mean when it says “ see sh ##”
does that refer to a sheet #? Where can I find it?
bhoeffner
Jan 18, 2013 09:00 PM
SD-Dave
Jan 22, 2010 02:57 PM
bigbaddiesel416
Mar 1, 2009 09:24 PM
MR HYDROSEED
Feb 16, 2007 07:03 PM
caleb
Sep 23, 2006 11:11 PM
