Windshield Wiper Bushing Replacement
Old Apr 18, 2009 | 08:35 PM
ouchman's Avatar
My wiper arms crapped out today so I bought the replacement bushings. The problem is THOSE LITTLE ARE HARD TO POP IN!
The one on the driver's side is under the cowl and I just can't seem to get at it to pop it in! It is not directly underneath the access hole and I just can;t seem to be able to get at it to pop it place.
PLEASE - any hints? I am so tempted to "enlarge" the access hole
Old Apr 18, 2009 | 08:39 PM
apwatson50's Avatar
Take all the linkage out of the cowl, replace bushings on bench, then re-install.
Old Apr 18, 2009 | 08:43 PM
1043's Avatar
DITTO - replace them all while you are at it. Use a little lithium grease and push them on with a "c" clamp.
Old Apr 18, 2009 | 08:46 PM
RollinCoalSmoke's Avatar
ouchman where did you find the bushings? It has flooded the last two days here and last night I found my noise, the bushings fixing to fall out. Thanks.
Old Apr 18, 2009 | 09:20 PM
ouchman's Avatar
HELP! part # 49440 - most auto supply stores
Old Apr 19, 2009 | 12:18 AM
Trooperthorn's Avatar
Yep, take out the linkeage. Dont forget the greese. The first set I did, I forgot the greese and didn't reaize it until I turned them on and they squeaked. 6 years later, they still squeaked.
Old Apr 19, 2009 | 12:22 AM
ouchman's Avatar
DOH!
Sometimes the obvious just isn't obvious to me!
Thanks for the help.
Old Apr 19, 2009 | 06:39 AM
Thanks ouchman. I see your a fellow Lonestar State 1st genner. I'll check the parts stores today. Appreciate the help.
Old Apr 19, 2009 | 10:23 AM
ChrisLib's Avatar
channel lock pliers are your friend
Old Apr 19, 2009 | 12:27 PM
james1's Avatar
Ditto. (And that is the tool recommended for this job in the FSM.)
Also see the following old post:
https://www.dieseltruckresource.com/...ighlight=wiper
Bill Gilbert provides the NAPA part numbers as well as complete instructions to complete the job. In addition to the channel locks, I used a small socket with some lithum grease to drive one of the new bushings into the steel linkage bar (on the workbench).
Old Apr 19, 2009 | 05:28 PM
ebteckx's Avatar
on my '76 i put a small socket over the bushing and used the linkage and a pair of pliers to pop em in place. Dont know if its the exact setup in our first gen trucks but it should be similar.
Old Apr 23, 2009 | 03:30 PM
ouchman's Avatar
Job done!
Easy Breezy when they are OUT of the truck. Ample grease applied to bushings - runs smooth as a Baby's Backside! Better than it EVER was before!
THANK YOU
Old Apr 23, 2009 | 09:42 PM
ebteckx's Avatar
I know that for the older cars, you can buy a kit to add a grease fitting to the pivot as well... dont know if that would work on these trucks too or not... just a thought
Old Nov 21, 2014 | 10:34 AM
james1's Avatar
Smile Reviving an old thread
After only six years, my wipers failed in a rainstorm and I have again replaced all four of my plastic bushings. I’m convinced the demise of the most recent bushings was hastened by the lithium grease I was using. This time I utilized pharmaceutical grade petroleum jelly (“Vaseline”) – hopefully I’ll see a little longer life from this set.
Old Nov 21, 2014 | 11:14 AM
j_martin's Avatar
Some, if not all plastic bushings are designed to run dry. I know that in trailer spring applications, if you grease the bushings in the rockers and spring ends, they'll wear through in a hear because the grease captures road dust and dirt and makes an efficient grinding compound out of it. Installed dry they last a long time.
There are dry silicone lubes, usually applied with a spray can, that give you the best of both worlds.
