Window Regulator
Old Jun 5, 2023 | 06:32 AM
bannerd's Avatar
Window Regulator
Anyone know why the little spring would keep jetting out when the window is down? Any idea what it does? I'm afraid it's going to smash the window because when it happens I hear a bang.. then it falls inside the bottom of the door.
Old Jun 5, 2023 | 07:57 AM
annywood's Avatar
As far as I know, the spring is likely part of the window mechanism, helping it move smoothly. If it's shooting out like that, it could cause damage if it gets caught in the wrong place. I think it's safer to avoid using the window until an expert checks it and fix it.
Old Jun 21, 2023 | 09:58 AM
Rug_Trucker's Avatar
5 Year Member
Electric or manual? Dorman window regulators are inexpensive.
Amazon Amazon
What year truck?
Old Jun 21, 2023 | 04:46 PM
There is usually a spring on the window mechanism itself which helps with the "lifting" of the window back up....if it's popping off and coming loose than the regulator is likely broken or worn out so badly the spring will no longer stay in place. Sounds like it's time for a new regulator assembly.
JamieA
Mar 11, 2021 08:09 PM
MARF75
May 3, 2013 09:28 PM
j_martin
Jul 15, 2012 11:26 PM
Snapper
Oct 16, 2007 06:48 PM
