Window motor question
Old Feb 19, 2008 | 11:11 PM
Gutterslug's Avatar
Just a quicky. My window motor on my drivers side hardly works worth a edit when the temp gets down below around 10 deg C (that's 50 F). This has been edit me off somethin' fierce over the last couple months but today after we get a little sun and warmth my window started working properly again. Sound like a problem worth a rebuild?
Old Feb 19, 2008 | 11:21 PM
Trooperthorn's Avatar
Here are the stickies on the rebuild.
Window motor repair (also covers R&R):
https://www.dieseltruckresource.com/d...d.php?t=100536
Window motor repair revisited - circuit breaker and brush replacement:
https://www.dieseltruckresource.com/d...d.php?t=141605
Old Feb 20, 2008 | 12:10 AM
Free89W350's Avatar
You could also try to spray some wd-40 or such in the track and on the moving parts of the mechinism and see if it frees up at all. I had the same problem and a little lube did me good.
Old Feb 20, 2008 | 09:40 AM
stackx2's Avatar
mine did that even after i rebiuld them. just lube them up i used white lithium grease on mine
Old Feb 20, 2008 | 03:10 PM
Loosewire's Avatar
Same Problem Here. There Is A Spray Version Of White Lithium Grease That You Can Get Just About Anywhere. Give Mine A Lube Once Or Twice A Year, And All Is Good.
Old Feb 20, 2008 | 03:15 PM
dodgethis91cmns's Avatar
deffinatly rebuild them, i did mine and its like new literally, they fly u and down, and then dont make a sound
Rednecktastic
Aug 29, 2010 11:26 PM
raven392003
Oct 29, 2007 11:39 AM
Common
May 9, 2007 12:11 AM
rottenron
Dec 8, 2003 09:30 AM
carl20320
Jun 23, 2003 03:15 PM
