Will POD'S Work for me,..?
Old Mar 16, 2009 | 07:43 PM
RamW350 dually's Avatar
Darrin, are your 6x.014 injectors for a non-intercooled or intercooled engine? Do you still have them and are they slightly used or brand new?
Old Mar 18, 2009 | 02:41 PM
DarrinGT's Avatar
darrin,I got an idea,i see you run a denny t fuel pin,put those big injectors in and put in stock fuel pin,rotate it from shallow side to deep side to see how much fuel you want. i ground my own pin,i run it on the dyno,made 330hp,but 1400 + egt , 40+ lbs boost,more turbo lag on the road.i rotate fuel pin to unground side untill boost about 38,egts 1200. truck spools quiker and i drive without worry . dont give up on injectors yet!
Thanks! I don't have the stock pin anymore, but when I did try these injectors it was still in the doner truck, with no intercooler and a restrictive exhaust. Not sure what difference that would make but it smoked way too much for that application. Well see i still own them but I have not got my truck out of winter storage yet, still working on some stuff on it so It will be a week or so before I get it back on the road and start playing with it.
Darrin, do you have a stick or an automatic tranny? If you have a stock auto, you're already on the ragged edge of what it can handle, especially towing.
Mike
Hey Mike I am not worried about the tranny, it has a built C6 Automatic with a low stall towing RV Converter and lots of cooling. Then I run a Gearvenders Overdrive Gear Spplitter that is rated for up to 1200 HP. So overall it is a pretty bullet proof setup.
Intercooled injectors can go in a non intercooled engine with little adapters that come with the injectors.
factory non intercooled injectors just CAN'T go into intercooled heads.
They don't even make aftermarket 9mm non i/c injectors....... you get 7mm's and use the adapters provided
That is my understanding as well, but I didn't know that you cant get the 9mm's anymore.
Non Intercooled, and slightly used.
Thanks again for all of the input,.. still deciding what to do,..
Old Mar 18, 2009 | 07:45 PM
crewcabxlt's Avatar
rig up a valet switch or set up afc for fuel control,put in the big injectors.see how it runs
BrokeSolid
21
Feb 3, 2009 09:36 AM
cheese4420
Apr 13, 2008 11:50 AM
scarecrow
Mar 9, 2006 08:12 PM
96_12V
Jul 7, 2005 11:26 PM
