where to hook up electronic fuel pressure gauge?
Well I finally got a fuel pressure gauge. I decided to go ahead and get an eletronic one so i didn't have to run fuel in the cab and have it illegal in competition use. So i ordered an isspro EV2 gauge from genos. It just has a pressure sensor and then wires run from that to the gauge. But wheres the best to place to put the sensor in? I know to put it after the fuel filter. Do i need to put a T in the fuel line and put this sensor in it? or can I use the bleeder bolt and use a fitting to get it to work since the sensor is bigger than the bleeder bolt. Or is there a way you can drill and tap another hole in the fuel filter housing and put it there? Just wonderin what everyone else has done? thanks.
That is what i did also but i needed to run a hose from the banjo to the sensor because the sensor was to large to connect directly. I think in the long run it was better doing it this way anyway account of the vibration of the motor it was directly connect to the banjo. Geno's also had the remote hose that i used with all the necessary fittings.
is this the bangjo bolt your talkin about??
http://www.genosgarage.com/prodinfo....BF-LONG-TAPPED
So i could pull my banjo bolt out, take the bleeder bolt out of that, then drill the hole bigger and tap it where the bleeder bolt was and just put my pressure sensor in there?
its too late, it came on tuesday, and i don't wanna wait and pay more shipping for a $7 bolt. I think I'll just drill and tap the one i have, and hope it doesn't break. Thanks for the help guys!
I would tap it while holding the bolt in a vise (Which I'm sure you were going to do for the sole reason of shards). I was thinking if it DID break, it would most likely break at the neck, leaving the banjo bolts threads inside your head
Advantage of the Geno's one is that the holes are bigger without sacrificing strength.
mstep3
Aug 30, 2009 07:27 AM
Ghost Ram
Feb 21, 2008 11:03 PM
hotdram
15
Mar 9, 2005 07:18 PM
ts
Oct 28, 2003 10:36 PM
tomsauto
Nov 18, 2002 07:22 PM
