where do the N/I heads usually crack?
Old Sep 4, 2008 | 06:27 PM
gear jammer 91"'s Avatar
I noticed today that there is slight hissing sound coming below the exhaust port in between the head and the block on my number 3 cylinder. Since non intercooled heads are prone to cracking and this seems to be such a small compression leak I am concerned that it is not the head gasket but actually a tiny crack in the head. I was hoping there was some way to rule out the head being cracked without removing it? Any help will be greatly appreciated.
Old Sep 4, 2008 | 06:34 PM
dieselJon's Avatar
I think between the intake and exhaust valves....
Old Sep 4, 2008 | 06:38 PM
kiohio1985's Avatar
I'm interested in this too...
and if there is something we can do to prevent it.
Thanks
Old Sep 4, 2008 | 07:32 PM
I don't think we can do anything to prevent it, but if it happens between the valves it is definitely not the issue I am having.
Old Sep 4, 2008 | 07:57 PM
Tron's Avatar
It happens between the injector hole and a valve seat. I don't know which one.
Old Sep 4, 2008 | 08:03 PM
pulltilbroke's Avatar
Best Paint (Getrag category)
My head is cracked in # 1 - 4 cylinders between the injector bore and the valve
I'm still running it with no ill effects
Sounds to me like you got a popped H/G
Old Sep 4, 2008 | 08:32 PM
bullfrog5.9's Avatar
they crack to in between exhaust ports. if u look at ur head and 98 one theres soo much more metal on 98 one
Old Sep 4, 2008 | 08:36 PM
I think it's the head gasket too, it's such a small leak, and it's leaking cylinder pressure, no mixing of fluids, so I think it's gonna keep leaking for a while.
Old Sep 4, 2008 | 09:09 PM
Exekiel69's Avatar
Well since there is no way to prevent it, what head is the best one to use in our motors?
Thank You.
Old Sep 4, 2008 | 09:55 PM
Richie O's Avatar
366 Spring Chicken
91.5 to 93 with the smaller ( more metal ) 7mm injectors.
Old Sep 4, 2008 | 10:33 PM
The 94 and newer heads have better air flow than ours I believe, witch would make more power. The thing I'm not sure about is if the injector angle is different?
Old Sep 5, 2008 | 08:33 PM
JQmile's Avatar
As far as I know you can swap the later head on with no ill effects. Pure Diesel Power sells em for less than a grand.
Old Sep 5, 2008 | 11:54 PM
loch's Avatar
If its a head gasket, fix it fast. The hot gas escaping can cut like a knife if unattended.
kawi600
15
Mar 7, 2009 03:27 PM
muddin_mavric
Sep 6, 2007 07:59 PM
Checkmate
Jul 15, 2007 07:29 PM
v8440
Oct 29, 2004 02:10 PM
PADZZ
Feb 8, 2004 07:47 PM
