What will it take
Old Aug 14, 2011 | 03:09 PM
bulltamer's Avatar
What will it take
What will it take to put 3rd gen dually rims on my '92 d350?
Old Aug 14, 2011 | 04:22 PM
cougar's Avatar
The problem is with the single wheel off set. Dualies should be the same regardless. The only thing my be the studs and lug nuts.
Old Aug 14, 2011 | 05:34 PM
bulltamer's Avatar
What size are the studs and where can I get them
Old Aug 14, 2011 | 07:14 PM
whiskers's Avatar
O'Rielys or any good parts house will have them or can get them. Up here we have a place called WC Supply. It is a clutch, springs, brakes, everything supply. I bet you got something similar in your area. They have access to every size made. If your later wheels need a bigger stud it easy to bore the hub holes and press in bigger studs as they have splines on them. I've put '96 duals on a '93 that way. You'll have to put the later nuts on also.
robb152's Avatar
i did it on my duely.. i really like it very easy just drill the third gen rims with a 5/8 drill bit i think i paid 25 4 it.
Old Aug 15, 2011 | 04:05 AM
bulltamer's Avatar
Ok thanks guys!
tomsauto
Jan 4, 2003 01:17 PM
DarrellB
Dec 6, 2002 07:28 AM
98rammer
Oct 16, 2002 09:58 PM
Dieseldude4x4
Oct 14, 2002 06:08 PM
Javaluva
Oct 10, 2002 07:17 AM
