what viscosity of Diff flluid do you use?
So I'm here...
Looking at the redline line of fluids:
high shock, thin high shock, 75/90 w, 75w/110 and 75w140.
I'm sure all will work fine.. but any suggestions? I'm in texas so cold weather operation is not a concern. I was leaning toward high shock (75/90) or 110 or 140w.
Anyone here have a particular flavor preference?
Michael
Michael
So I'm here...
Michael
Michael
It's also not very good in your hair as I found out.
When I purchased my 1994 Toyota hilux pickup, the owners manual stated 75/140 for just about every part of the truck which required gear oil.
Since then, it's all I used.
The difference between multi-grade and straight-weight oil is simply the addition of a viscosity improving (VI) additive. The most common grade of automotive oil in use today is the 5W/30, which is a mineral oil refined with VI additives that leave it reading as an SAE 5W viscosity when cold, yet an SAE 30W when hot (210F). The advantage to the multi-weight is that when starting the engine, the multi-viscosity oil (with its thickness of an SAE 5W when cold), allows the engine to spin over more easily.
https://www.blackstone-labs.com/oil-viscosity.php
85-140 'cause I traded a case of Yuengling Lager cans ($20ish AND generally accepted legal tender here in PA) for 4 cases of Kendall 85-140 gear oil.
Guy I got it from was dumping it into his waste oil furnace occasionally to get rid of it!!!
Call them, and ask. See if they say the same thing to you.
Just so you know, Amsoil doesn't recommend the friction modifier for use with their severe gear products. I use the Amsoil 75/140 severe gear in the brick and my fuso, and I actually called them about the LSD in the brick needing the additive. They swore up and down that I would NOT need it, as it's already formulated in it. They told me to put it in straight, and forget about it. So I did.
I recently had a hard pull to do. Put 4 black streaks on the pavement getting the furniture van out of the ditch.
s. hale
Mar 11, 2008 11:04 AM
royta
Oct 24, 2007 10:16 PM
wheels
16
Nov 15, 2002 10:46 AM
