Diff. Oil viscosity
Old Dec 7, 2004 | 04:30 PM
fortylove's Avatar
Diff. Oil viscosity
What diff. Gear oil viscosity do you heavy haulers use? 75W90, 75w140 or 80w140. I have enough 75W90 Redline for two changes & now understand DC changed recomendation to 75W140.
Old Dec 7, 2004 | 05:04 PM
MikeyB's Avatar
If you're not doing heavy towing the 75w-90 is fine. Heavy towing 75w-140 is preferred. I would go ahead and use up the Redline lube.
MikeyB
Old Dec 9, 2004 | 10:17 AM
Rattletrap1's Avatar
You can save the 75-90 for the front.
At least on my 2nd gen DC ALWAYS said 75-140 synthetic for the rear if towing heavy. Why they didn't supply it (even with factory tow pkg.) is a whole other question.
Old Dec 10, 2004 | 12:15 AM
Hemi Cat's Avatar
Check out the synthetic oils for the diff's. They are very good.
Old Dec 10, 2004 | 05:08 PM
Casey Balvert's Avatar
I am using Redline 75W140. The axle went south with the DC stuff in it about 3,000 miles ago. Never again.
Old Dec 11, 2004 | 11:43 AM
Bertram65's Avatar
Is there a TSB for the 75w140 reconmendation? What is the source?
Old Dec 12, 2004 | 07:34 AM
roadrat's Avatar
75/140 tsb. 03-001-04 rev a, found at dodgeram.info
rob
s. hale
Mar 11, 2008 11:04 AM
royta
Oct 24, 2007 10:16 PM
jgn
May 13, 2005 09:44 AM
wheels
16
Nov 15, 2002 10:46 AM
