What type of oil
What type of oil
What type of oil do yall run in your diffs. What do recomend? I am doing a compleate seal replacement in front and back diffs and just wondered what the best oil to use is.
I wouldn't mess around... put real gear oil in there. 75W90 or so if it's a regular work truck, 75W140 if you tow. Mobil makes a synthetic that says "LS" on it for Limited Slip, so it has the additive already in it. If you have an open diff, don't bother with the LS additive.
After that... it's all brand preference. I want to say the rear end holds closer to 4 quarts and the front around 3 if I remember correct....
Don't even bother buying gaskets for the pumpkin cover. Both my surfaces were pristine, and they still leak like a sieve. Use some RTV for your gasket, and only finger tighten your bolts and allow the RTV to set. Then, the next morning you can ease them up with a ratchet when the RTV is dry.
EDIT:From the sticky: D70 rear = 7 pints (3.5 qt) and D60 front = 6.5 pints (3.25 qt)
Fluid capacities:
https://www.dieseltruckresource.com/d...d.php?t=204044
Fluid capacities:
I run royal purple 75/140. I get it real real cheap, thats my reason. Before I was running gm 75/90 full synthetic for the same reason as above! Both have and are working real good for me. Not sure on the price if you buy it at the counter. I think the royal purple is cheaper than the GM stuff?
I too am using Amsoil 75W90 and have been for quite a few years. If you tow quite a lot 75W140 is a good choice. What I found out about 75W140 using oil analysis was that 75W140 retains all too much water unless you tow enough. It does not heat up enough under moderate towing and daily driving to burn off water and temperature sensitive comtaminents.
Bob
Bob
I just got some of the Mobil 1 75-90 LS to do a fluid change and was wondering if the amount of additive already mixed with the fluid enough, or will I need to add some of the Mopar stuff as well?
kram
Aug 29, 2007 11:01 AM
