What size?
I think it's 14mmx1.5, but I'm not certain. There's a metric to flare adapter that the pipe connects to. If you figure it out, please post it. I'm looking for a push-lock connection to put in there, myself.
Here you go :
http://www.discounthydraulichose.com...068-parent.htm
I have never seen a straight screw-in metric/push-lock fitting that accomplishes it in one piece.
What you will need is whichever one of these JIC metric-male adapters you require to screw into the pump or whatever; then, to get from there to rubber push-lock hose, you will need the appropriate push-lock "swivel", either straight, 45*, or 90*.
That link has the best prices and good quality stuff of anywhere I have been able to find and I have about looked at them all.
I used a 1/4 (npt i think, the pink pakage) to 3/8 barb into the the adapter that was already there. And I got rid of the banjo bolt and put a tee straight off the block one side go's to the pump, and the other to a gauge.
schoust
Oct 21, 2009 10:09 AM
bigdogtruck
18
Nov 21, 2007 08:09 PM
