what should my peak boost be with 21cm?????
Old Jan 17, 2008 | 09:22 PM
pwrtripls1's Avatar
I have ground the fuel pin, advanced the timing almost to the head, open air filter, short strait pipe coming out in front of rear tire. I have not touched the fuel screw yet, its still in the stock possition.
So, what should I be seeing for peak boost right now?
Old Jan 17, 2008 | 10:15 PM
BC847's Avatar
1st Generation Admin
Depends, . . . . . what's your EGT at WOT?
And what boost figure are you seeing?
Old Jan 17, 2008 | 10:20 PM
Micaiahfied's Avatar
a stock intercooled auto will see about 12, 5-speed is probably 14-18. fuel pin will add a few pounds but the timing bump will take some away. I'd say you should be somewhere around 20 without touching the fuel screw depending on how much you ground the pin.
Old Jan 17, 2008 | 11:02 PM
MikeThomas's Avatar
Im going with 16.
Old Jan 18, 2008 | 12:46 AM
SuperiorRam's Avatar
mine was 20
Old Jan 18, 2008 | 01:01 AM
Tron's Avatar
Id say under 20. With whats done in my sig minus the 3200spring I was maxing at 22psi ands the fuel screw is turned in I just dont know how far. Ive tuned it to egt's
Old Jan 18, 2008 | 09:15 AM
pwrtripls1's Avatar
Im seeing 24-25 psi right now, just didnt know if that much boost with so few mods was normal.
Old Jan 18, 2008 | 12:44 PM
Oldschooldodge's Avatar
With mild pump tweaks, and 190's, the most I ever saw was 22psi towing with the 21cm.
PeytonMaterne
Dec 7, 2005 11:15 PM
Boatnik
Aug 16, 2005 08:14 AM
HOHN
Jul 29, 2005 02:07 PM
Blueturbo
Oct 22, 2003 09:40 AM
