What needs to be looked at when replacing the rear main seal?
Old Oct 17, 2007 | 10:55 PM
NoSparkplugs's Avatar
Question What needs to be looked at when replacing the rear main seal?
So I'm going to go get my rear main seal for my truck since its in dire need of it. While I'm at it, I'm going to replace the clutch with a Southbend Con OFE kit. Is there anything else I should replace while I'm in there? Also, last time I got a seal from my local cummins dealer, it was almost highway robbery on the price, are NAPA seals any good or should I stick to a genuine cummins seal?
As well the gaskets for the mating surfaces on my tranny to transfer case, tranny to bell housing are shot. Can a guy get these at NAPA or are they Dodge specific? Could I use a thick bead of Ultrablack RTV in place of the gaskets?
Thanks in advance
Lucas
Old Oct 17, 2007 | 11:36 PM
RuralCruiser007's Avatar
You can get a Felpro rear main gasket set. It comes with the rear main seal and the adaptor mating gasket. When you go to put the adaptor gasket on make sure it sits right. The gasket is a little long and you will have to cut it down a bit. At the corners where the gasket meets the block and oil pan, put a small dab of RTV silicone before you assemble.
With any seal I always pack the backside of the seal with grease so as to not have the spring fall out. I have had the spring fall out a few to many times and hate fighting to get it back in. I also hate installing a seal dry.
You should be able to get the gasket between the transfer case and transmission without a problem. A good parts guy should be able to help you out.
HTH
Old Oct 18, 2007 | 05:42 AM
JD730's Avatar
I use ultrablack on the trans to transfer case joint on my truck, so I don't see any issues there. Tranny to bell housing????? There shouldn't be any gaskets there, there's a drain in the bottom of the bellhousing anyway. How much was the price, last one I bought was around $44 I think.
I don't know about the Felpro seal/gasket set, but I know with the Cummins seal that is MUST be installed dry, it is not a rubber seal, it is telfon. And there is no spring on a teflon seal.
sootnsmoke
Jul 17, 2011 06:31 AM
ted_pulliam
Aug 4, 2010 11:33 AM
bnold
Jul 7, 2007 06:18 PM
Jezzhuntin
Sep 7, 2006 01:37 PM
westcoaster
Sep 1, 2003 01:32 PM
