What happens when your vacuum pump stops working.
Old Oct 11, 2018 | 04:38 PM
  #31
Jim Lane's Avatar
FWIW,
You will probably have to go to a specialty fastener store to get the grade-8 stud.
Don't be tempted to use a piece of all thread, it may strech or snap off inside the gear and cause more problems.
Lube the stud where the nut contacts the washer.
Jim
Old Nov 14, 2019 | 12:41 PM
  #32
Jadenbrown's Avatar
Bearing
Do you or anyone know what size the bearing is or a part number
Old Nov 26, 2019 | 04:20 AM
  #33
KRB's Avatar
KRB
Does the vacuum power anything else other than the brakes? My pedal is now getting hard but everything else seems to work.
Old Nov 26, 2019 | 05:06 AM
  #34
nonrev's Avatar
Super Moderator
10 Year Member
KRB, it also powers your heater controls, but I believe they stopped using the diaphragm pump in the intercooled models
I found a pretty informative vid on you tube detailing testing your vac system and brake booster
Old Nov 26, 2019 | 03:15 PM
  #35
dodgenstein's Avatar
Also runs cruise control and goes to low vacuum sensor below driver's side hood hinge.
Old Nov 29, 2019 | 06:35 AM
  #36
KRB's Avatar
KRB
I still have cruise so it might be my booster.
Thanks for the video Nonrev, I'll have to dig out my vacuum gauge and check my booster now. Pretty cool to find a video specifically for our trucks. I also noticed he has one on the rotors & king pins which I'll watch. I did the passenger side king pin already (about a year ago) and need to do the drivers side plus rotors now.
Old Oct 25, 2021 | 07:22 PM
  #37
Roger Martin's Avatar
89-91 Dodge Diesel vacume pump
Originally Posted by jimbo486
Do you have the 2 diaphragm type vacuum pumps or the vein type vacuum pump? Being that your sig only shows '92 model trucks/vehicles, you should have the vein type pump. However, you mention a diaphragm is why I'm asking.
The diaphragm vacuum pumps can't be resealed, only replaced at the cost of about $160 each. The vein type pumps can be resealed. The reseal kit for the vein type pumps is Cummins P/N 4089742.
I just ordered two of the
Dorman 904-809 Vacuum Pump for Select Dodge Models
canisters (new) from Amazon for $87.87 each
Old Aug 31, 2024 | 02:51 PM
  #38
Barend's Avatar
p/n 6008
Old Aug 31, 2024 | 02:57 PM
  #39
Barend's Avatar
Excellent writeup! Just did this. Only thing i find strange that after its all together, the gear can move up and down from the housing about a 16th of an inch. So i took ik apart again and found its the shaft of the power steering pump that can move up and down a bit. Its brandnew. So i checked my old one and it too does that. So should be good. Just find it very strange as i cant see why that gear should be able to move up and down while spinning so fast. @U2slow checked his pump for me and said his gear doesnt move up and down a bit. The intercooled style pump i have laying around also doesnt. Again, i find it strange and dont feel good about putting it on a brandnew engine...
jimbo486
May 8, 2016 06:07 PM
heykw
Aug 24, 2009 10:15 AM
5.9Excursion
Jul 25, 2007 09:42 PM
SN162
Jun 30, 2007 10:10 AM
PourinDiesel
49
Sep 11, 2006 06:27 PM
