What flex plate to get?
Old Feb 1, 2011 | 08:59 PM
roccoboost's Avatar
I just ordered a Goerend converter today to replace the totaly worn out stock one on my truck . I am not sure if I should just get the second gen flexplate which I can get pretty cheap, or should I get one that is beefed up a little more with an insert welded (laminated?) into the second gen flexplate? I plow with the truck, but otherwise I dont really use it for anything heavy duty. I ocassionally tow a car trailer, but not the weight that a lot of you guys do. The truck is pretty much stock now, but I plan on doing some pump mods in the future along with some other bits. Eventually 300-350HP. What do you think?
Old Feb 1, 2011 | 09:41 PM
Onemoparnut's Avatar
The stock second gen flex plate should be just fine.
Old Feb 2, 2011 | 07:59 PM
KD93's Avatar
x2. You'll have no problems with a 2nd gen one at that power level.
Old Feb 2, 2011 | 11:59 PM
Dean Snow's Avatar
for the extra few dollars of getting the insert if your worried about it at all why not do it now while your there. could save time money and hassle later
are you talking about the after market insert that you weld onto the flex plate around the center ring
Old Feb 3, 2011 | 09:30 PM
roccoboost's Avatar
The upgraded flexplate is more than just a few dollars over the stock plate unfortunately. I think I might just get the stock plate instead. After thinking about it more maybe the upgraded plate is a bit of overkill for what I plan on doing. Man I cant wait for that new converter!
The_Head
Nov 30, 2008 10:17 PM
Igor
Mar 26, 2006 10:11 AM
whazzup
Aug 24, 2003 08:21 AM
CR7135
Jul 14, 2003 10:19 PM
