What Evaporator Temperature should the Compressor Clutch Open?
Old Jun 25, 2012 | 06:45 PM
Bruce M's Avatar
I found that my Clutch Cycling Switch Relay was shot, so I changed it with one from Pick-a-Part Junk Yard.
With an outside temperature of 82 degrees the Evaporator Air was reading 40 degrees on max flow.
When I switched to Max Air(recycling cab air) the Evaporator Air was reading 33 degrees when the Compressor Clutch opened and recycled.
Do I have the Temperature set to low?
Or should I pull the Probe out of the Suction Line a little to up the temperature?
Old Jun 25, 2012 | 09:21 PM
Pulling the probe out makes the temp go down. 33 sounds OK to me, just don't run the fan on low. Bleed in a little heat if you get too cold.
Sent from my Paranoid Android HD2 using Tapatalk 2.
WhoCares79
Jun 3, 2008 11:45 AM
73ShovelHead
13
Aug 30, 2007 09:09 PM
Camarogenius
Jun 25, 2007 08:55 PM
Desert Diesel
Mar 18, 2007 08:53 PM
JKM
Mar 8, 2006 03:23 AM
