Old 02-25-2019, 07:17 PM
  #7096
Received 1,332 Likes on 862 Posts
Yeah I'm not a fan of the white faced gauges either.
Old 02-25-2019, 07:59 PM
  #7097
edwinsmith's Avatar
Received 1,038 Likes on 763 Posts
I permanently wired the pigtail to the battery so I can hook up the trickle charger without opening the hood. Took all of 10 minutes. I don't like it because the stupid radio drains the battery when the truck sits for so long. I don't get to drive it much anymore.
Old 02-25-2019, 08:41 PM
  #7098
N. Besonderes's Avatar
I would appreciate any suggestions for how I could safely remove black paint from a Ram hood ornament.
I bet that if I gave it enough time, it would just remove itself.
Old 02-25-2019, 10:53 PM
  #7099
edwinsmith's Avatar
Try soaking it in boiling water. It works for house paint.
Edwin
N. Besonderes (02-26-2019)
Old 02-25-2019, 11:33 PM
  #7100
Remove it and put it in a container of vinegar for a few days, or brush on some brake fluid over a week or two it might lift the paint?
Old 02-26-2019, 03:59 AM
  #7101
maybe368's Avatar
A product called aircraft remover. Don't get it anywhere that you don't want paint removed though. I would remove it first:
Amazon Amazon
...Mark
Old 02-26-2019, 05:25 AM
  #7102
I was thinking I would try aircraft paint remover in a small spot and see if it would bubble up the paint without eating through. I've only used it on metal before.
Vinegar or brake fluid seems like the safer thing to try first though. I'll give it a shot this weekend.
Old 02-26-2019, 10:59 AM
  #7103
maybe368's Avatar
My ram's head is metal, probably pot metal, but still metal. What is yours made of?...Mark
Old 02-26-2019, 01:24 PM
  #7104
ChrisLib's Avatar
Put my new chrome grille on over the weekend.
Also swapped out the gauge cluster and bezel in the new Ramcharger with one that I happened to already have. I hate white-faced gauges.
-Niemand
Nice ride, the grill looks good. Hill Country area?
Old 02-26-2019, 01:48 PM
  #7105
FrustratedFirst's Avatar
Lacquer thinner. Take it off the hood and pour 1/2" in small bowl metal or plastic, soak it and use tooth brush to scrub.
The following 2 users liked this post by FrustratedFirst:
N. Besonderes (02-26-2019), thrashingcows (02-26-2019)
Old 02-26-2019, 02:01 PM
  #7106
New motor Mounts, Front Sway bar, wired up courtesy lights
Wired into door switch and dome light! Old man can see now!
Also wired the daytime Running Lights of LED headlights to key "on" circuit.
Modern conveniences
Old 02-26-2019, 06:28 PM
  #7107
I'm up in Williamson County. I bought my truck from a cedar chopper out near your neck of the woods in Pipe Creek.
ChrisLib (03-05-2019)
Old 02-26-2019, 06:44 PM
  #7108
The one on my pick-up looks like it's made of plastic with a metal shell. You can see where it's peeling off a little.
I put a rare earth magnet on it and it barely wanted to stick so I'm guessing it's a low grade stainless foil (302 or 304). Aluminum wouldn't have grabbed it at all. Definitely not metal on the inside and it's not a knock-off.
-Niemand
maybe368 (02-26-2019)
Old 02-26-2019, 06:48 PM
  #7109
maybe368's Avatar
Well I'll be danged, I think that mine is the same, I wouldn't use airplane stripper the, that stuff is strong...Mark
Old 02-26-2019, 07:02 PM
  #7110
It certainly does remove paint though.
Quick Reply: What did you do to your Gen 1 today?
