What a day
What a day
Well today on my way home I took a back way so I could take a 0 to 60 video to post up here. The first try I lost traction bad so I stopped and just rolled into the throttle. Everything went well till I let off the throttle and I heard the horrible sound of the fan eating my radiator. The fan shroud was broke in the center at the bottom and the fan had hit the rad. I bent the blades away from the rad and drove it the 1/4 mile home. I pulled the rad and saw that the fan had hit the little strap that is made on the rad. There are 2 straps on each side they are maybe 1/4 inch wide. I am not sure if the fan was pulling so much air that it sucked the strap back into the fan, or if the shroud broke and the fan hit it then bent and hit the strap and the strap beat the crap out of the rad. Either way I need the truck bad tomorrow so I pulled the rad and removed the 5 cores that were leaking and soldered the holes up in the tank. I dont really think that the 5 missing tubes will make much difference in the cooling. Oh and to make it worse the videos are all messed up anyway. How can I take a video on my phone then when I try to play it back it says the video in in an unreadable format? Stupid smart phone!!!!!
sorry
sorry
I experienced a similar mess. The stock/OEM fan blade had developed cracks around the root of the blades. Spinning things up had the weakened blades move forward and into the radiator.
2500TurboDodge
Apr 7, 2005 01:49 PM
muddymess
36
Apr 18, 2003 01:12 PM
