Water Meth question
Old Mar 10, 2007 | 08:20 PM
Micaiahfied's Avatar
Water Meth question
how much methonol % wise does the product "heat" have in it? hopefully i will be able to get some real methonol monday, but until then i would like to play however i want to play safely!
Old Mar 10, 2007 | 08:34 PM
Ace's Avatar
Ace
Just get a jug of windshield washer fluid. The ordinary cheap stuff is about 50% methanol.
Old Mar 10, 2007 | 08:54 PM
i tried some WW fluid... said it contains Methonol, i highly doubt the mix was 50/50.
Old Mar 10, 2007 | 09:23 PM
BC847's Avatar
1st Generation Admin
The heat stuff is pretty close to 100% meth if I'm not mistaken. (Be aware that some of the gas-driers is Isopropal alcohol, . . close). Also, look at the other brands closely as most are Meth and are less expensive than Heat.
The typical blue stuff is in the range of 20% to 30% for the winter blends.
Seems I read somewhere here that a member cyphered ~ One gallon of the blue stuff plus two bottles of the heat gave approximately a 50/50 blend.
Your mileage may vary.
Regardless, it's expensive to mix this way but it'll do well in a pinch.
Outside of your normal race vendors, check around for some local go-cart enthusiasts as they may know where to get the meth.
Hope this helps.
Old Mar 10, 2007 | 09:33 PM
loch's Avatar
Micia is hooked, his trucks an alcoholic,,,gee thats odd.
Old Mar 10, 2007 | 09:41 PM
loch's Avatar
oops i forgot to answer your question. this is a breakdown for everyone.
+20 F Washer Fluid - Contains approximately 7% methanol.
0 F Washer Fluid - Contains approximately 23% methanol.
-10 F Washer Fluid - Contains approximately 28% methanol.
-20 F Washer Fluid - Contains approximately 35% methanol.
-25 F Washer Fluid - Contains approximately 38% methanol.
-50 F Washer Fluid - Contains approximately 62% methanol.
Old Mar 10, 2007 | 10:04 PM
Ace's Avatar
Ace
Looks like -20 and a bottle of the meth Heet will just about do it.
jdpiii
Jun 19, 2008 07:34 AM
stock600
Apr 29, 2008 11:40 PM
Mike T.
Aug 25, 2007 09:02 PM
BigBlue
Feb 7, 2007 10:50 AM
omaharam
Apr 7, 2006 07:48 PM
