water in fuel
Old Mar 6, 2010 | 02:18 PM
petrecca8's Avatar
water in fuel
ok so i was out washing my truck and lifted the hood and noticed it was pretty dirty so i sprayed the crap out of it with the hose. i thought afterward i wonder if water could have gotten in to the engine. well i went and turned the key to see if the water in fuel light came on and it did. what could have happened? i had disconnected the censor on the fuel filter because it went bad so where else is there a sensor to try and help narrow watever this is down
Old Mar 6, 2010 | 03:26 PM
BearKiller's Avatar
It is probably ruined beyond repair.
Or, you simply shorted the water-in-fuel circuit; the light should go out when the water dries; UNLESS, the pressure of the water somehow smashed the two wires against each other.
Old Mar 6, 2010 | 03:56 PM
Jim Lane's Avatar
Just blow out the WIF sensor connector with compressed air and the light will go out. I wash my engine compartment every time I wash my truck and this happens sometimes because I lost the rubber gasket from the inside of the connector.
You could try to pack the connector with dielectric grease to waterproof it.
Jim
Old Mar 6, 2010 | 04:02 PM
petrecca8's Avatar
thanks guys
ZPOD
18
Sep 23, 2010 10:37 AM
DodgerDoob
Oct 1, 2008 07:49 AM
nooska
Jun 19, 2008 08:30 AM
kev211
14
Feb 22, 2007 03:39 PM
Gene Peterson
Jan 7, 2006 02:32 PM
