Wandering steering/bump steer
Old Jan 28, 2017 | 05:11 PM
Alec's Avatar
From the FSM:
"(3) The camber angle should be adjusted as near as possible to the preferred angle. The caster should be the same at both sides of the vehicle. Refer to the Specifications chart."
If I am reading your sheet correctly, I think that you need more camber, and that you have excessive cross caster (less positive caster on the left side to counteract the tendency for caster to pull "down" the crown of a road, that is, to the right).
Old Jan 28, 2017 | 05:48 PM
1972RedNeck's Avatar
Originally Posted by Alec
From the FSM:
Looks like he needs a bit more caster too.
Old Mar 6, 2017 | 06:45 AM
Gizmo52's Avatar
From the FSM:
Just an update everyone! truck drive good now. the alignment wasn't way off but i guess it was enough to make everything drive like junk... turns out my that someone had dropped on of the heads for the alignment rack when my buddy did the alignment. took it to a different shop and all is good now!
Thanks for the help everyone!
Old Mar 7, 2017 | 07:06 AM
Same thing happened to me.
Brought my dodge to one shop, and the alignment wasn't right, even though they were all fancy dancy computerized up.
Brought the dodge to a "Truck spring shop" that had one of those fancy dancy computerized gadgets, and the truck has been perfect ever since.
Old Mar 7, 2017 | 10:32 AM
mknittle's Avatar
On my 4wheel drives I do my own. I have had so called alignment shops do mine and brought it home and redid it so it was right. So much for being lazy.
3500CTD
Aug 12, 2010 01:55 PM
afoulk
Jan 10, 2008 12:24 AM
2006 MEGACAB
34
Jul 19, 2007 09:37 PM
2006 MEGACAB
Jun 29, 2007 04:54 AM
jkap
Nov 9, 2006 06:36 PM
