vids of the chevy/cummins on the dyno
Nice runs. sounds good
Are you on www.fullsizechevy.com or any other forums? i recogniize your username
fully ported and polished head ,exhaust manifold ,tubo housing ( 12cm ) , marine head gasket , special head bolts , 60# springs, 3200 gov spring , stage 3 cam , denny t pin , marine injectors , hx35/hx40 turbo , 96 airintake ,96 intercooler , fuel screw 1/2 turn from runaway smoke screw all the way in , egt gauge , boost gauge , nv4500 trans .
should i be pulling more than 43-44 pounds of boost ? thats all i can pull with the boost line unhooked from the waste gate . i was wondering if the waste gate i sticking open a little .egts are way to high to for all my mods ther maxing my gauge right now , i would guess somewere in the 2000+ range when you flat foot it threw the gears .
so what do u all think about getting the egts lower ? i have a 18.5 cm housing out for porting right now , im going to try that first . then maybe get rid of the 4 inch exhaust and go with 5 inch .
what is a 60 mm turbo ? how much bigger is it ? why will it help the egts ? i dont know anything about these turbos , this is a pure tow pig thats why im so worried about the egts .
your not saposed to correct a turbo'd engine.
a 60mm turbo upgrade will flow slighly alittle more air than the HX35. but if you want to tow with lots of power you should go to a bigger turbo. an s300 based turbo. my plan is to get a 62/71/12 or 14 someday.
