vids of the chevy/cummins on the dyno
Old Feb 7, 2009 | 01:21 AM
JQmile's Avatar
Those are some nice numbers! Spray more bottle if you want to lower EGTs
Old Feb 7, 2009 | 09:29 AM
flippy1974's Avatar
Originally Posted by Alwaysworking
your not saposed to correct a turbo'd engine.
a 60mm turbo upgrade will flow slighly alittle more air than the HX35. but if you want to tow with lots of power you should go to a bigger turbo. an s300 based turbo. my plan is to get a 62/71/12 or 14 someday.
send me a link to this s300 so i can check it out , if u dont care .i didnt know u wasnt suppost to correct the dyno #s on a turbo motor .
Old Feb 7, 2009 | 09:32 AM
flippy1974's Avatar
thanks man . i thought about putting a kit on it and dynoing again but that isn't going to help when I'm towing with it so i don't know .
Old Feb 7, 2009 | 03:30 PM
crewcabxlt's Avatar
for towing & torque down low a 12cm housing might work better,i tested towing light [6000 lbs] up 6% grades 70 mph & found the 12 on my setup was better than 18 or 14 housing i run a hx off a 98 24v,smaller comp wheel.[54?] but i read somewere higher map effeciancy than p-pumped hx. cools boost to 36-38 towing.
Old Feb 8, 2009 | 12:07 PM
flippy1974's Avatar
i think wth all the porting the 18cm wont hurt me that bad . right now it has no turbo lag at all .i was hauling my 36 ft trailer and a t-type buick regal and a rx7 with a ls1 swap and i was pulling my buddy from red light to red light in his nissan ultima
Old Feb 8, 2009 | 02:46 PM
crewcabxlt's Avatar
i think you low elevation guys cnn spool bigger, quiker than were i,m at. very good.
Old Feb 8, 2009 | 05:02 PM
flippy1974's Avatar
PeytonMaterne is was good to meet u today . thanks for the pillar pod !!
Old Feb 8, 2009 | 05:57 PM
PeytonMaterne's Avatar
Thanks for the ride. This truck is pretty stout fellers.
Old Feb 8, 2009 | 07:35 PM
flippy1974's Avatar
thanks man , i cant wait for a ride in yours !
Old Feb 8, 2009 | 07:42 PM
Which one? He has like 3.
Old Feb 9, 2009 | 05:01 AM
flippy1974's Avatar
i dont care , 1 or all of them .
Fire Rescue124
Apr 28, 2010 06:11 PM
2141pete
NCDTR #18
17
Nov 15, 2007 08:00 PM
dieselfuelonly
NCDTR #18
100
Nov 14, 2007 04:15 PM
35" 05'
17
Feb 19, 2007 02:29 PM
BigBlueDodge
Aug 1, 2005 02:24 PM
