VE front seal questions
I bought a regulator but I wouldn't mind adding some assurance and maybe even try running the truck with just the high pressure lift pump without the regulator.
For clarification, this sucker is the front seal right?
Now if that thing gets pushed out from too high pressure, I assume the pump gear doesn't press right up against it? Why not just have something machined to fill the gap between the gear and IP so the front seal can't get pushed out from the pressure? Of course you'd have to measure the gap and all but why not?
Or am I missing something here...
The gear turns; the seal doesn't.
Some have pressed the seal in a bit further and put a lock-ring/snap-ring in a machined groove.
The problem with that approach is that the shaft is tapered and the seal I.D. is too small to be further up the shaft; I don't know how they addressed that issue.
Another approach I have seen is to drill/tap three holes around the housing, such that the heads of large-headed machine-screws over-lapped the edges of the seal.
I am not saying they can't, but I have read and heard much talk of the seal pushing out, but I have never read of anyone's that actually did.
Some time back, there was a very lengthy thread on this very subject, complete with bunches of good pictures of both fixes.
Maybe someone can point us in the direction of that thread.
I have not done either modification myself; I just know both have been done by others.
it sure would be nice to see this thread you're talking about. I am going to maybe try to secure the front seal and run my high pressure second gen piston pump without a regulator.
As per your other thread I may even try running this banjo on the fuel inlet right off the pump. That way I know what the pressure is right at the pump.
http://www.torkteknology.com/product...PN-BBS010.html
sootnsmoke
07-17-2011 06:31 AM
92smokin blacky
01-04-2011 12:43 AM
RTillery
02-07-2009 08:46 AM
dieseljerk
07-08-2004 07:23 AM
