ValveBody Removal Tip's...Please
Old Jun 22, 2008 | 03:04 PM
CrewCabCummins's Avatar
Can anyone give any Tips or useful Links for a A518 or 727 would be great..At the moment I need to know how to Unhook the Internal shift linkage that's attached to the top of the valve Body..THANKS in Advance!
Old Jun 22, 2008 | 03:40 PM
Fred Swanson's Avatar
For the internal park rod, move the external shift lever all the way forward to put the VB in first, that will expose the e-clip. Use a long thin screwdriver and a magnet tip to pop it loose and catch it.
Old Jun 22, 2008 | 03:48 PM
THANK YOU !!! Do you happen to know what the symtoms of the vale body "the TORX one's" TOO Tight? I'm getting a FLAIR and a LOUD Groaning sound as it shifts into 3rd..any idea what could be Groaning inside?
Old Jun 22, 2008 | 03:56 PM
Does it actually go into 3rd? How's reverse? It sure sounds like the forward clutch is toasted.
Old Jun 22, 2008 | 04:47 PM
Im looking inside of it now...it all looks fine..I have the valve body apart now and it seems to look fine also...anyone have a pic of where the ***** go back in..Im 99% sure i know where but would like to be 100%..Yes 3rd and reverse shifted fine..is the rear band 72in lb then 2 3 or 4 turns...thank you
Old Jun 22, 2008 | 08:51 PM
badme's Avatar
I think you need to keep pulling it apart. Your problem is in deeper than a valve body and band adjustment.
Txwelder
Feb 22, 2008 04:55 PM
007c
Jan 2, 2006 03:52 PM
keithplacervill
Nov 6, 2005 10:44 PM
Mike D
Oct 13, 2004 02:52 PM
jbevly
Mar 18, 2004 08:53 AM
