727 valvebody
Old Dec 29, 2005 | 01:20 PM
007c's Avatar
727 valvebody
Hi anybody know where i can find the best valve body for a 727 non lockup It seems we now have 3 crooked valvebodies....
Also need something powerful but that shifts smoothly.
Old Dec 29, 2005 | 02:36 PM
Winr's Avatar
What do you mean "crooked" ? I have always used B&M shift kits when I wanted to improve (stiffen) shifts
If they are warped how did thet get warped?
Old Dec 29, 2005 | 03:47 PM
007c's Avatar
Well one is because of a bad local tranny rebuider not torquing to spec never going back there...The others i'm guessing overheating one has unknown history... What i now find curious is tranny rebuilder told that the casing is broken and valvebody is warped... but replacement casing has a warped valvebody too and probly wants to sell one at insane prices....
The broken casings is kinda why i need something that shifts smoothly since always doing rev to 1 then back to rev all the time pushing snow all the time is very hard on a tranny....
Old Dec 29, 2005 | 05:13 PM
Winr's Avatar
I've been rebuilding/building 727's (and others) for 20 years and I dont think I've ever seen a warped VB out of a 727/904. I have seen the check ***** wear through the seperator plate but not warped.
Old Dec 29, 2005 | 06:53 PM
007c's Avatar
well these trannies are used for snow removal which is much worse than towing.I guess the heat gets to it.
Old Dec 30, 2005 | 12:04 PM
007c's Avatar
I found someone claiming to have a good body but says this:
Well, the only way we can put it together to match a diesel application is to put a shift kit in it.
This is after i asked if it was perfecly straight before that all was fine but not guaranteed...
I'm wondering if a normal 727 valvebody for tf 727 car trannies can be used with and adjustable shift kit? Anybody had any experience with that ?
Old Dec 30, 2005 | 01:02 PM
Mcmopar's Avatar
Depending on who's "shift kit" you buy you can custom taylor shift points etc. There are different springs that you can buy to change the governor too. If you talk to someone who designs these units the can set you up. I have piles of 727's floating around, what year are you looking for? Give Dave Goerend a call, he is a great guy and works with the Diesel automatic trannies. 563-778-2719
Old Dec 30, 2005 | 01:26 PM
007c's Avatar
Well not sure what year i should be looking for but its a 90 3 speed nonlockup. I will give Goerend a call since nobody in canada has any that are guaranteed to be good non warped.
As soon as i mention broken casing ppl seem to run away in chaos....however i have a good casing now.
Old Dec 30, 2005 | 02:14 PM
Mcmopar's Avatar
What about SMR transmissions in Canada? Pat Story is the owner and he has always been good to me?
Old Jan 2, 2006 | 10:59 AM
007c's Avatar
Thank you ! Also found out why it warped... With all the metal shavings from broken casing it blocked the valvebody and that's how it overheated.
Old Jan 2, 2006 | 11:10 AM
Mcmopar's Avatar
Plugged up with all the metal?? Can you say abused??
Old Jan 2, 2006 | 03:52 PM
007c's Avatar
Yea but then again had no choice 50 cm's of snow in 2 pases 12hrs of snow removal ahead including commercial properties and no spare.... I beleive its the back pulling (back dragging corners etc) that killed it however after the last time it was fixed you couldnt let the truck parked in a not so steep hill or the park would disengage and you'd see the truck waiving goodbye as your running behind...
bryceepoo
16
Apr 30, 2006 01:58 AM
Leon441
0
Jan 13, 2006 08:17 PM
keithplacervill
Nov 6, 2005 10:44 PM
Mike D
Oct 13, 2004 02:52 PM
jbevly
Mar 18, 2004 08:53 AM
