vaccum?
Old Jun 16, 2009 | 01:43 PM
1stgenjake's Avatar
vaccum?
where can i pull vaccum for my boost controler?
Old Jun 16, 2009 | 02:18 PM
apwatson50's Avatar
Well you could tap in somewhere in the vacuum lines near the brake booster, but I don't see how a constant source of vacuum is going to operate you're boost controller?
Old Jun 16, 2009 | 02:25 PM
1stgenjake's Avatar
i don't know either. I bought a manual boost controller (like for a turboed car) to control the waste gate actuator on my HE351 last night and it says that i need vaccum and boost signal. I will have a **** to adjust psi in the cab so it should be nice if i can get everything to work. I also need to relocate the actuator on the compressor housing to line up with the lever arm in the waste gate because the way a HE351 needs to be clocked to fit a first gen is much different than how it is on a 3rd gen
Old Jun 16, 2009 | 09:34 PM
Alwaysworking's Avatar
alwaysonDTR
on a gas car the intake would give you vacume and boost in the same line when the turbo is makeing boost, i think you just need a boost signal unless the controller you bought has more than 2 lines?
Old Jun 16, 2009 | 09:39 PM
1stgenjake's Avatar
ok so i just need a line off a charge pipe like where my boost gauge is and one to the waste gate actuator
Old Jun 16, 2009 | 09:57 PM
alwaysonDTR
should be,
boost from mainifold to boost controller to wstegate accuator
Old Jun 16, 2009 | 10:02 PM
1stgenjake's Avatar
ok cool. i guess the hard part will be getting the accuator moved where it will line up with the waste gate again (because of how the turbo is clocked)
jrs_dodge_diesel
Nov 25, 2004 03:04 PM
OHFarmboy
Mar 16, 2004 09:13 AM
JCHMOTOR
Jan 8, 2004 09:56 PM
yrusoslow2
Jun 16, 2003 05:28 PM
yrusoslow2
Apr 25, 2003 01:13 PM
