upper and lower radiator hoses
Old Jun 14, 2006 | 04:41 PM
bigragu's Avatar
Lookin' to replace these pretty soon. anyone have the NAPA part #'s for these? How often are you all changin' out the t'stat? If I do change out the stat, should I stay with stock, or is there one better in the aftermarket? Please advise, and thank you in advance.
Old Jun 14, 2006 | 04:53 PM
bgilbert's Avatar
Thermostat- have you changed it in the past couple years? If it's working good and or it hasn't been more than a couple years since you changed, I'd leave it be. Cummins only t-stats. $30 piece, so if it's not old, leave it be. NAPA has the best hoses IMO. I don't know the numbers on them, they'll fix you up. By no means though, don't get a NAPA t-stat. Junk out of the box, cycle worse than a Cummins stat. Don't get me wrong, I'll use them in my gassers, but the 6BT.
Old Jun 14, 2006 | 08:05 PM
blueberry's Avatar
The correct thermostat is Cummins 3917324. I would change it every 4-5 years.
Brian
Old Jun 15, 2006 | 04:59 PM
bigragu's Avatar
I've got part #'s for those that need them
All NAPA
Upper Hose: NBH8620-$17.69
Lower Hose: NBH8327-$18.69
Misc. Heater Hoses: NBH7296-$4.50. You will need 2 of these 90 degree hoses.
1- 5" piece of straight 5/8" heater hose. This will need to be trimmed to fit.
Round up your clamps and that should do it.
Old Jun 15, 2006 | 10:24 PM
BearKiller's Avatar
I didn't know any better and picked up my thermostat at Advance.
It works fine; the temperature gauge reaches a certain point and remains there, mile after mile, up hill and down, loaded and empty.
Old Aug 14, 2006 | 07:14 PM
charliex25's Avatar
I did the same thing about getting a 180 thrmo at napa but I tested it in hot water and it dident open untill 195o. I dont know the difference between a cummins. Can anybody explain?
charliex25
Old Aug 15, 2006 | 01:46 PM
cLAYH's Avatar
Cummins is fully open at 180*, NAPA starts to open at 180*. I run a Cummins one in summer and a NAPA one in winter for more cab heat.
EdmontonCanada
37
Feb 4, 2016 12:02 PM
12valvin
Feb 3, 2011 07:47 AM
AlpineRAM
Sep 3, 2006 04:29 PM
Fishbait
Nov 17, 2004 12:07 PM
