Radiator hoses and noise
Old Sep 2, 2006 | 02:42 AM
AlpineRAM's Avatar
I've had some rodent damage on one of the 90deg rubber hoses on my engine, so all the coolant went for a stroll on the highway - since the 90deg bends weren'T available I replaced all the small lines with 16mm radiator hose. I had to remove the hard lines and do a bit of routing for the hoses. I did also replace the hoses to the heater core.
The amazing part of the result is that the engine is a whole lot quieter, especially inside the cab. Most of the hard metallic rasp (very hard to describe) is gone.
I can't exactly tell which hose accounted for the biggest noise reduction, but I assume it's the one from the heater core to the block close to the water pump.
Just thought I'd share this experience
AlpineRAM
Old Sep 3, 2006 | 04:29 PM
jimk's Avatar
AlpineRAM
At least you did not burn up your engine. Thanks for the info on reducing noise in the cab. The older I get the less I like the noise. Jim
PRO-NRA
0
Jan 2, 2010 03:36 PM
bigragu
Aug 15, 2006 01:46 PM
