Upgrade Turbo
Old Jul 7, 2009 | 11:03 AM
Ridiculies's Avatar
Upgrade Turbo
My friend has a 92 diesel, would a turbo off an 06 work, and what would he have to do to make it work. Thanks
Old Jul 7, 2009 | 02:28 PM
1bad93's Avatar
it all depends thiers a few people running the he351 turbo but if its a 6.7l engine they have varible vains and thats a little tricky to make work.
Old Jul 7, 2009 | 03:28 PM
soggy's Avatar
Its an 06 so its a 5.9, it will work well, you need to get a 4in flange for the downpipe, fab up an intercooler pipe, or reclock the compressor housing. You also need to pull the studs out of the turbo flange, probably reclock the exhaust housing to get the oil feed/drain to line up. No big deal really and the guys that have them are very pleased.
Old Jul 7, 2009 | 05:38 PM
Ridiculies's Avatar
Thanks Soggy, my friend helped me with the install of my turbos so I'm sure he will be able to make it happen. Great info.
Old Jul 7, 2009 | 05:48 PM
1bad93's Avatar
i thought some of the 06's were 6.7's
Old Jul 7, 2009 | 06:06 PM
92smokin blacky's Avatar
no they went to 6.7 in 07
Old Jul 7, 2009 | 06:13 PM
apwatson50's Avatar
End of 07, you could get either 6.7 or 5.9 in 07
Old Jul 7, 2009 | 06:48 PM
1bad93's Avatar
oh ok
Old Jul 7, 2009 | 08:38 PM
To answer the question, yes an 06 turbo can fit on a 92 with some work.
And from what i hear, You'll love the results
Old Jul 7, 2009 | 09:14 PM
1stgenjake's Avatar
i love mine...still no waste gate tho, 50 plus psi makes scary sounds when you get carried away and let it. and it will spin the turbo backwards if you lift hard and kill the engine like a pulling tractor...need BOV and to hook up mt gate with the boost controller
Old Jul 7, 2009 | 09:27 PM
Ridiculies's Avatar
Thanks to all for the help.
Old Jul 7, 2009 | 10:07 PM
Riflemanusmc's Avatar
Registered user
One of the cheapest, and best FACTORY upgrade's you'll do....
NJTman
Jul 4, 2012 11:55 PM
Ada381
Feb 10, 2008 07:58 AM
LilBigd02
Feb 28, 2007 08:31 PM
12valve
14
Feb 22, 2007 09:07 PM
jrs
Apr 13, 2003 06:34 PM
