Upgrade on stock 1993 12 valve
Old Aug 9, 2017 | 06:06 AM
RJC's Avatar
RJC
Truck has been down for awhile and finally getting it back on the road. Researching any info on intake cool air upgrade also suggestion on getting upgrade parts. I'm just trying to getting little better towing power. Have 4" exhaust installed next week.
Any info on what I could do to increase power,
Any info greatly appreciated
Old Aug 9, 2017 | 07:52 AM
The sticky is excellent for providing guidelines for increasing "power".
but the standard reply still applies.
You need gauges.... Pyro, boost, fuel pressure (at a minimum)
Bigger / Ford Intercooler and tubes is a good way to get more air into your ride. Quite a few threads on the PS upgrade, lots of pics too
366 spring will make your truck wake up
Turn your stock fuel pin to the deepest setting
Replace your hc1 with a better turbo / bigger / smaller exh housing for better / faster spooling.
Old Aug 9, 2017 | 08:00 AM
mknittle's Avatar
First of all gauges. Boost and pyrometer are most important for tuning.
then the free pump mods and see how you like it.
I too want to build a outside air intake system.
Old Aug 9, 2017 | 09:40 AM
bigragu's Avatar
The factory air filter box pulls air from the outside, but it for sure does not ram the air in. If you look at the intake duct directly under you passenger side headlight, you will see that there is a sheet metal trim piece blocking direct ram air from entering that snorkel. The trim piece sits halfway behind and on top of the bumper.
Armed with precise measurements, you can take your tin snips and cut out a nice rectangular opening, and put that door edge protective plastic "V" trim over the cut edges, and it'll look like it grew there.
Then you got ram air.
Old Aug 9, 2017 | 09:12 PM
mknittle's Avatar
I didn't word that correctly
What I am thinking is build an air box to isolate the air filter from the hot air in the engine compartment as much as possible, with a bigger intake to the box.
Old Aug 10, 2017 | 05:23 PM
BC847's Avatar
1st Generation Admin
https://www.dieseltruckresource.com/...air-box-63169/
Old Aug 10, 2017 | 05:37 PM
mknittle's Avatar
Thanks David,
that's a pretty cool way to do it.
Old Aug 10, 2017 | 11:04 PM
IdahoJoe's Avatar
5 Year Member
I asked the same question. Pretty much the same answers.
https://www.dieseltruckresource.com/...2-d250-324172/
So far, fuel pin and gauges are done. I have a governor spring and 16cm^3 exhaust housing to put on. I'm trying to keep my trans alive so I've been slow to crank up the power.
Old Aug 15, 2017 | 10:13 PM
RJC's Avatar
RJC
sorry had trouble with my computer, Ive seen pix but cannot locate how you can modify your stock intake air for better flow? Getting exhaust done next Sat.
Old Aug 16, 2017 | 08:09 AM
samiam4's Avatar
I think they drill a bunch of holes in the housing to allow less restriction from the snorkle.
Old Aug 16, 2017 | 09:45 AM
mknittle's Avatar
what year is your truck?
Old Aug 16, 2017 | 10:01 AM
IdahoJoe's Avatar
5 Year Member
Look at the thread title...
Old Aug 16, 2017 | 02:54 PM
mknittle's Avatar
Duah
Old Aug 16, 2017 | 09:56 PM
RJC's Avatar
RJC
I thought I seen that on one of the sites but cannot locate. Just getting ideas how to convert stock for more air flow
Old Aug 17, 2017 | 08:12 AM
mknittle's Avatar
I just took a 2" hole saw to mine. I drew lines across using a square marked and pilot drilled 1/4" holes. Then the hole saw.
