turned fast and motor died
Old Oct 5, 2008 | 03:39 PM
randyswelding's Avatar
howdy again,last night i went crusin and was fallowin a riced up honda when he went around a corner and i had to fallow him,i had plenty of room to stop,but i had around 20psi of boost and let off and went around the turn and the motor died.this is the first time for that(it did it one other time but i know why,a large deep water puddle at the highway exit flooded out the air filter and got a lot of water in the turbo,but i did see really cool egtsthen after sittin for a little it fired right back up,so with that i figured alot of water goin threw the turbo isnt good)!i pulled over and a friend had spot lights on his new cummins and craked 2 injecter lines and pushed the lift pump button to see if i had fuel and i did,then took off the air filter tube to look at the compresser wheel and it look fine still,then tried startin it again and it fired up and missed a bit then rebleed those same 2 lines and it smoothed out.what did i do?it has me and a few friends and my dad confused!thanks for any ideas
Old Oct 5, 2008 | 07:35 PM
I got it! you may have been low on fuel and you came around the corner and the fuel slushed to one side of the tank ,and the pickup line didnt pickup enough fuel and it ran the Injection pump dry momentarily and put air in the lines. But when you stopped it slushed back and thats why it started right up after the bleed the lines. Were you low on fuel?
Old Oct 5, 2008 | 07:44 PM
that would be awsome if i was near empty but i filled up about 20 to 30 miles at loves before it happend,but man i didnt even think of that
Old Oct 5, 2008 | 08:30 PM
Maybe you flooded it . too much fuel and not enough air just like a gas engine. lol
Old Oct 5, 2008 | 08:45 PM
Weak lift pump or a leak in the supply lines.
Old Oct 5, 2008 | 10:29 PM
Tron's Avatar
Loose Wire in the fuel shut off?
Old Oct 6, 2008 | 06:21 PM
no shut off,got gutted,and it has a brand new pistion liftpump,where and how would i check to see if there leakin?i havent seen any fuel dripin or sprayin fuel?
Old Oct 7, 2008 | 06:41 PM
Lightly pressurize the fuel tank (air hose and a shop rag in the fill hole) and look for drips from all connections.
Also look at the fuel heater gasket.
Old Oct 7, 2008 | 08:00 PM
wanna diesel do you know what part numeber the fuel filter addapter with out the heater is?and this weekend i got to put a clutch(dads truck) and radiator in my truck and if i got time this weekend ill try that shop tawle and air hose deal and ill let yall know
Jim Lane
Dec 7, 2015 09:16 PM
EdmontonCanada
37
Dec 9, 2009 03:18 AM
Dale M
Feb 10, 2009 09:43 PM
Emoneysrt-6
Oct 21, 2008 11:17 AM
trik396
Mar 14, 2007 07:57 AM
