Turn signal-wiper stem-handle
Old Jun 25, 2013 | 05:39 PM
maybe368's Avatar
When I was disassembling the stuff in the steering column, I found that the handle/stem for the turn signal is broken at the base, where it is held in by 2 torx screws. My first thought is JB weld, but does anyone know if this part is available? What is it called? In the meantime, I am going to be jb welding ...Mark
Old Jun 25, 2013 | 06:04 PM
Not sure if it's available in the aftermarket...but you can find them used. You might have to get one form another Dodge ram though. Think the Dakota was different? I usually find them listed under "turn signal switch".
I used one from a 90 in my 89 column....had to cut and and splice the wiring to make it work. Colors and wire routing changed, but function stayed the same.
Old Jun 25, 2013 | 06:16 PM
maybe368's Avatar
Thanks, when I search switch, none of them include the stem part. Guess I'll go take a look in some wrecking yards. For now, I think JB weld is the answer...Mark
Old Jun 25, 2013 | 07:19 PM
Isn't it called the "multifunction switch" ?
Pretty sure dodge still carries them, and they're not super expensive......
although I could be wrong...
Old Jun 25, 2013 | 08:15 PM
Jim Lane's Avatar
Check Dorman and Standard for aftermarket multifunction switches.
Old Jun 25, 2013 | 08:29 PM
maybe368's Avatar
This is what they show for a wiper switch and a turn signal switch. Problem is that the stem is what I need. The stem screws onto the part that is facing down on the wiper switch...Mark:
Attached Thumbnails Turn signal-wiper stem-handle-wiper-rock-auto.jpg   Turn signal-wiper stem-handle-turn-switch-rock-auto.jpg
Old Jun 25, 2013 | 08:33 PM
maybe368's Avatar
This is what I have. It is broken between the 2 screws....Mark
Old Jun 25, 2013 | 08:35 PM
Onemoparnut's Avatar
http://m.autozone.com/autozone-mobil...ction%20switch
Old Jun 25, 2013 | 08:37 PM
maybe368's Avatar
That is nothing like what is on there...Mark
Old Jun 25, 2013 | 08:50 PM
crazy clem's Avatar
on my 92 w 250 the standard brand part no was ds 739 this no is 3 yrs old though. on standards website it lists a # for int wipers and non int wipers
Old Jun 25, 2013 | 09:24 PM
patdaly's Avatar
FWIW parts manual shows it as part of the switch assy whole assy is P/N 5600 3556
Bet it ain't cheap either. 1990 looks to be it's own animal.
Old Jun 25, 2013 | 09:47 PM
maybe368's Avatar
Do you have the part # for the wiper switch? That would be helpful...Mark
Old Jun 25, 2013 | 10:59 PM
Yeah I'm pretty sure you can't separate that handle/stock from the wiring. Since the intermittent wiper, and wash function is built into it.
Like I said I used a 90 one in my 89 column...same exact design, just wired slightly different. Think the dodge rams, and vans, went to this around 86/87. Probably have to find one from one of those years and then make it work.
When my 89 stock was acting up I was searching on E-bay for them...found a couple used ones. So they are out there. I'll keep an eye open for one.
Old Jun 26, 2013 | 07:47 AM
patdaly's Avatar
Uh, yes?
Old Jun 26, 2013 | 09:41 AM
maybe368's Avatar
Uh, yes?
That number comes up as just the turn signal switch. I cannot find anything that includes the stem...Mark
