Turn Signal issue
Old May 15, 2024 | 12:23 PM
DevoWaters22's Avatar
Turn Signal issue
I installed Grote 44891’s LED Flashers and I only get one flash per side then nothing after that, I got LED’s in all 4 corners plus the side marker lights up front, whatever side I add a incandescent bulb to in the turn signal socket, it works perfectly normal along with the side marker light…..what can be my problem?? Thanks
Last edited by DevoWaters22; May 15, 2024 at 12:52 PM. Reason: Forgot to add something
Old May 15, 2024 | 02:07 PM
edwinsmith's Avatar
Try a different flasher or else add a 10 ohm resister in parallel to the led's on each side.
Old May 15, 2024 | 02:49 PM
to each led as in just the turn signals up front or the front side markers too? Thanks
Old May 15, 2024 | 10:16 PM
edwinsmith's Avatar
Should be sufficient to just add them to the rear brake circuit on each side unless the turn signal has a separate bulb.
rustydiesel
Oct 15, 2021 07:50 PM
Double "L"
Dec 27, 2011 05:42 PM
SWC
Nov 27, 2009 07:46 PM
NotEnufGarage
Sep 12, 2008 05:43 PM
gcliburn
Oct 5, 2006 04:58 PM
