Turn Signal
Old Dec 26, 2011 | 06:46 AM
Double "L"'s Avatar
Turn Signal
I have a 2000 3500 laramie. The turn signals work fine until I turn the lightns on. When I do turm on the lights the left turn arrow on my cluster lights up. The right turn signals work fine but have no left? Anyone had or seen this issue?
Last edited by Double "L"; Dec 26, 2011 at 08:33 AM. Reason: placed the wrong year
Old Dec 26, 2011 | 10:20 AM
zthatzmanz28's Avatar
Have you visually confirmed the light flashes outside when headlights are off? Does parking light come on with headlights?
Is one or the other burnt out?
Old Dec 26, 2011 | 12:44 PM
Double "L"'s Avatar
All lights blink and light up with the lights off. Yes parking lights come on with headlights. I can move the turn signal switch up and down and make the left blink, but I guess that is just inturpting the power and then back on. Checked all the bulbs and they all are good and work.
Old Dec 26, 2011 | 01:14 PM
torquefan's Avatar
I would try replacing the front and rear bulbs on the left, regardless of whether they work. Sometimes one of the filaments can break inside the bulb and contact the other filament, creating a short between the park and turn signal circuits, which would create the exact problem you are having.
Old Dec 26, 2011 | 09:35 PM
Double "L"'s Avatar
OK, Thanks, will give that a shot tomorrow and see what happens.
Old Dec 27, 2011 | 05:42 PM
klcammie's Avatar
also try clean grounds on the left lights front and rear. sounds like the park lights are grounding thru the turn signals.
ccolko
Jul 12, 2004 11:33 AM
hoot
May 25, 2004 11:52 AM
Richard Cox
May 20, 2004 11:21 AM
Jambbii
Apr 27, 2004 12:01 PM
