turbo swap questions for dummies
Old Jan 27, 2012 | 10:31 PM
hogdog05's Avatar
I have a 93 d350, intercooled, with a getrag. Only thing I've done is turn Tue pump up. I believe the truck should have a 18.5 cm turbo on it. I have a 24valve motor with an auto trans. The turbo on the 24 guts are trashed. My question is could I swap houseings using my inners from the 93 to the 24 valves houseings. Another issue I see is the 24 valves is wastegated and has a totally different way of hooking up to the exhaust pipe. I am really green on all this but gotta learn some how. Any help would be greatly appreciated. Also what is,the turbo off the 24 valve.
Old Jan 28, 2012 | 07:27 AM
bradshaw106's Avatar
I'm confused??? Your d350 has the original 12v? Or have you swapped a 24v into your truck......
Your 24v should have a hx35 or hy35 depending on the year. I'm pretty sure you could swap your older turbo on to your 24v and just swap exhaust housings...
Old Jan 28, 2012 | 08:01 AM
delsilver's Avatar
I can't answer the question but I think he is saying that he has a spare 24V engine and tranny with a good turbo and wants to put the guts of his spare 24V turbo into the housing on his on his 12V engine.
Del
Old Jan 28, 2012 | 09:47 AM
crewcabxlt's Avatar
putting the 12cm exhaust housing from any 94 to 98 or 98-02 24v 5spd is a nice upgrade over the worthless big housings. however if your using the turbo off a 99-02 24v with an auto trans its a hy-35 with a 9 cm exhaust. you cant swap parts off that to your h1c. 98 24 v autos had a 7 blade hx-35 .
Old Jan 28, 2012 | 07:59 PM
hogdog05's Avatar
Crewcab I think u answered my question. I have been know to confuse people from time to time. Basicaly I wanted to see if the houseing off the 24v would fit on my 93 d350. With just my pump modded would it make that big of a difference getting a smaller houseing. I pull a lot of heavy loads with this truck.
Old Jan 29, 2012 | 08:13 AM
I have a 12cm on my truck , but I don't haul heavy loads. I was under the impression the the 12 was not ideal for hauling?? Someone else will chime in with more insight then me.
Old Jan 29, 2012 | 08:32 AM
sooty's Avatar
you could get a ungated 12cm housing to speed the spoolup, i ran one for quite some time and really liked it, new should be around 150. or put a want ad for used and save, you wont have to modify anything, just bolt and go
GBRACER
Aug 18, 2005 03:05 PM
SHARPMACHINE
Aug 2, 2005 11:32 PM
rico334
Oct 8, 2004 11:53 AM
dcwm
Aug 3, 2004 08:34 PM
lezmark7
Mar 24, 2003 09:54 PM
