Turbo has no waiste gate.
The turbo on my new 1st gen (which is an hx 35) doesn't have a waiste gate on it. I haven taken delivery of the truck yet buy i noticed this in the pictures. Is this a problem? Also is it beneficial to have one and is it possible to install one?
Thanks, Coop
Thanks, Coop
It is entirely possible to put a non gated housing on an hx 35. There are non-gated 12, 14 16 18 and 21cm housings that will bolt right on. Depending on the power level you're after, even a non-gated 12 is not an entirely bad thing, as it will only become restrictive above about 250 rwhp.
Why do you think you need a "waiste" gate? Do the boost numbers skyrocket when you floor it above 2000 rpm? How are the EGTs?
I'm running an HX35 with no wastegate and my pump CRANKED. I can peg my 35 psi gauge if I really try. But driving empty even with my foot in it my egts hardly hit 1000*. Towing my jeep, which was only a 6k lb load and mostly steep grades i never hit over 1200*. And I tried to keep it under 25 lbs of boost unless I had to get on it. I would say don't worry about it unless your constantly towing or your egts and boost run high.
blow off valve goes in the intake tract to relieve pressure when the throttle blades are closed on a gas engine. You don't have any throttle blades to close so no worries.
WG or not depends on your application and what you want out of the truck. A 16cm Non WG housing would probably be fine, but you will have some lag. The Non WG housings are just simpler since they have less parts and are geared toward industrial, constant rpm/load applications where they are fine tuned and the engine never changes. A WG housing offers better flexibility in an automotive setting where the rpm and load changes all the time. You can have quick spool up and not choke the engine (within reason)
fjbiker86
08-02-2006 08:34 PM
Haulin_in_Dixie
23
03-31-2005 11:53 PM
