turbo charger silencer ring...
Old Aug 26, 2003 | 09:30 PM
adamroofer25's Avatar
I heard that you could remove the silencer ring from the stock Holset Turbocharger. Is this true and if so is this difficult?
Old Aug 26, 2003 | 09:43 PM
formula's Avatar
Re:turbo charger silencer ring...
On the 1st gen trucks, the stock turbo (H1C) does not have a silencer ring. Those who state they've removed it either have a later model truck, or have upgraded their turbocharger to an HX35.
Sean
Old Aug 26, 2003 | 10:02 PM
Thanks for the input. I was just out in the dark, fumbling with the flashlight, and I could see that there wasn't one there. I thought it had already been removed.
Old Aug 27, 2003 | 11:10 PM
BIGOKIE's Avatar
If you want more whistle you can take a dremel tool and cut the groove into the wall between the inner and outer horns (i call them) . Look at a 94 or later model turbo right behind the leading edge of the fins and you will see the groove. This takes alot of patience and precison but it sure will whistle.
Old Aug 28, 2003 | 10:10 AM
formula's Avatar
Dremel tool If you were set on doing that, I'd at least turn it on a lathe. If memory serves correctly........that channel is for "map width enhancement", providing more airflow and improving the efficiency map.
Sean
Old Aug 28, 2003 | 11:42 AM
BIGOKIE's Avatar
Yea that would be better but at the time it was the closest thing I had to a "lathe" It was just a experiment as I replaced it with HX 35. It did whistle considerably louder than the HX35 does.
BIGOKIE
Old Aug 28, 2003 | 11:16 PM
Bushy's Avatar
Patron Saint of 1st gens
Man, if you're willing to do that much work with a dremel tool, you deserve the ......
"5 Bonus HP for the Truely Commited CTD'r"....
Pastor Bob.
Old Sep 4, 2003 | 09:28 AM
cethane's Avatar
Does anyone know where there's a pic that shows what this groove looks like in an HX35???
RonP
Feb 17, 2010 09:30 AM
RRC
May 13, 2007 11:45 PM
HaulinBut
May 12, 2006 03:06 PM
StrokeThis2500
Dec 31, 2005 05:19 PM
